1st time using DIM, but installed G8 doesn't appear in DS - SOLVED
launoklaunok Posts: 807
edited June 2017 in Daz Studio Discussion
I have just downloaded and automatically install G8 via DIM.  Only Genesis appear in DS.  I also note that I have now a separate folder under My Documents called My Daz3D Library where G8 is.  Normally I have DAZ3D where Genesis is and all other items.  What should I do?  Copy the installed folders out of My Daz3D Library over to DAZ3D directory?
Post edited by launok on
  • nonesuch00nonesuch00 Posts: 18,763
    edited June 2017
    Personally, I would uninstall G8 and then carefully go through all your DAZ & DIM file system location settings and update the locations to where you'd like them to be and then reinstall G8.
    Post edited by nonesuch00 on
    You probably need to add \C:Users\Public\Documents\My Daz 3D Library as a content direvtory
  • frank0314frank0314 Posts: 14,726
    My Daz 3D Library  is the default folder for DIM that everything should install to unless you change it.
  • SimonJMSimonJM Posts: 6,071
    Very, very small issue of semantics, I think that "should" should be "will" - "should" suggets it is 'proper' for it to go there, whereas the location is entirely down to the needs or whims of the user.
  • launoklaunok Posts: 807
    Finally I got G8F to work.  I have moved the 'My Daz3D Library' directory into the 'Daz3D' directory under 'Studio'.  Now I have 3 sub-directories: My Library, My Daz3D Library and My Daz Connect Library.  G8F loads perfectly this time! laugh
    Note that, if you intend to use DIM to install other stuff, you must change its default content installation location to match the D|S content loading location. The two programs don't talk to each other; if you change the location settings in one program you must also change the location settings in the other.
    Also, if all you did was move the content folders, DIM might now consider G8F to be not installed and might install any updates into the same "wrong" location.
    @SpottedKitty - thank you.  I was myself thinking about this for future use of DIM since I have not used it before now. yes
