Great lashes for Gen 8 female problem
Is anyone else having problems with this product. When I load just the eyelashes with nothing else in the scens the morphs are there and fine.When I load a model the basic Gen 8,V8 etc the eylashes do onot have the morphs. When I delete them (eyelashes) and re load them thru the anatomy folder they still do not have the morphs as long as the figure is in the scene.
As a side note I feel Daz should compensate those having problems with this new model (Gen 8 Female) it has been riddled with problems and the time taken out to fix these problems is time wasted .
    It may be worth reporting this as a bug.  The morphs are there they are just hidden so you need Show Hidden Properties checked to see and use them.
    Well thank you how would I go about "show hidden properties", and I did report this. I'm not really a tech type person I install and use that's about all I know.
    It is in options, the little square with a tiny triangle and 3 (or 4?) lines at the top right of any pane.
  • fastbike1fastbike1 Posts: 4,081
    edited June 2017
    @cradzinski_3dd03228a0  "When I delete them (eyelashes) and re load them thru the anatomy folder they still do not have the morphs as long as the figure is in the scene."
    I agree that a better readme would help. They are tricky and I have a question in about the render, but the morphs can be found in the Parameters tab. See the screenshot.
    488 x 950 - 97K
    Post edited by fastbike1 on
  • barbultbarbult Posts: 26,451
    The tricky thing is that the morphs show up under Genesis 8 Female in the Parameters pane, not under the Eyelashes.
  • I found them thanks so much for the help.
    It was about two hours after I had posted that I remembered that I had seen the FWArt lashes morph when I was morphing the figure,s eyes.  It makes sense really that DAZ decided lash morphs should appear in the figures morphs as lashes in previous generations where part of the figure model.
    If you're still having problems, check this thread: https://www.daz3d.com/forums/discussion/176541/commercial-great-lashes-for-genesis-8-available-now#latest . I got a detailed reponse from Virtual World on applying the lashes.
