Autofit G8 Accesseries?
I've found you can autofit any old stuff that comes labeled as 'wardrobe' pretty good, but 'accesseries' haven't been addressed to speak of.  If you try to put on an old dress or shirt you're ok.  A bracelet or ring?  No such luck.  It winds up floating in mid air, mislocated by the difference between the new G8 default pose and the old G3.  Is this something that could be addressed?
  • FSMCDesignsFSMCDesigns Posts: 12,846
    Accesories are not usually figures with rigging, but props. props are parented, so just load it, then move it into position and reparent it and save for future use.
    Greetings,
    I managed to autofit a bracelet and necklace reasonably well, modulo my own mistakes.  I selected G8F and double-clicked on the necklace/bracelet, and selected what seemed most appropriate.
    In fact, I think one of them was a G2F item, since it didn't have Iray materials at all.
    --  Morgan
  • BlantyrBlantyr Posts: 90
    Yes.  I did a few manual fits.  It certainly can be done, but I find it tedious.  For the time being, any image that might use significant accesseries is done with G3.
  • ChangelingChickChangelingChick Posts: 3,366
    Put G8 in a t-pose before you load in the accessory and parent in place. Adjustments should then be minimal.
  • FistyFisty Posts: 3,416
    Yes, this.  Left/Right Shoulder Bend: 48 / -48
    For most of the earrings I've made you'll need to load them without having G8 selected and then parent them to her head.  If you try to auto-fit them they'll look like they've worked fine but when you tilt her head there will be no way to  pose them to follow gravity because it will have stipped out the extra bones I put in my earrings for those adjustments.  If you're using earrings for G3 they'll be in the right place (if loaded when G8 is in starting pose), for G2 you'll need to move them forward or back a bit to be in the right spot.
