Why is the DAZ Install Manager Download So SLOW?
2»
  • takezo_3001takezo_3001 Posts: 2,026
    I have a 1mbps connection here (before anyone remarks: can’t get any better on my side of the world). Every other site, and even direct downloads from DAZ, easily manages an average of 60KB/s, 80-100kB/s at peak speeds.
    DAZ Install Manager averages less than 10KB/s with occasional peaks at 17KB/s, and an average of four to five download failures per file. Tell me again, what’s the use of such a tool?
    I have a 75 MBps connection which equals a 11 mbps when downloading files, with DIM I'm getting 1.0 mbps instead...On a tuesday, 9:30 PM eastern...
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    There must be a lot of installing going on today because my internet dl speed is 25.1 mbps and DIM shows a dl rate of 410 - 600 kb/s.  I thought something was wrong with my DIM and googled my way to this page.  Probably should just have searched the forums first, duh.
  • luci45luci45 Posts: 2,891
    It is slower than dial-up for me today.
  • frank0314frank0314 Posts: 14,713
    Because of the V8 launch. The server is overloaded.
  • jesperlhnjesperlhn Posts: 0
    Currently download a fresh install of all.
    Download speed: 10-35 kb/s
    I got a 110 mbit down/up-load line.
    Its under all critiism how slow this is.
  • glenncuneoglenncuneo Posts: 11
    edited July 2017
    Pure amatures at slowness.... had it down to 239 bits per second this morning.....sometimes dropping down to 63 bits per second!  WOOHOO!
    Post edited by glenncuneo on
  • Silver DolphinSilver Dolphin Posts: 1,638
    Daz DIM needs a 64bit upgrade and more options. Like installing zips and meta data creation tools.
  • fixmypcmikefixmypcmike Posts: 19,692
    It doesn't need to be 64-bit, it doesn't handle that much data.
  • It should NOT be 64 bit, it will just use more ram without being faster, DIM is not slow, the DAZ servers may be slow at times, nothing DIM can do about that.
  • lorddayradonlorddayradon Posts: 539
    Still seems slow.   I have a 125Mb  (mega bit /s )  DIM is downloading at 52KB/s (or 416Kb/s) so my other 100 or so Mb/s is idle.  sheesh that's less than 1% of my available throughput.  You'd think with the noney they make they could upgrade their servers/infrasture, or improved peering connections.
  • randynrandyn Posts: 4
    I have a 1 GB fiber ethernet connection in the Great Lakes (midwestern US) area, and I'm getting 66 Kbs, Not Mbs, Kbs.  This reminds me of dial-up speeds 20 years ago. It took over an hour to download one purchase, and I have 3 more to go.  I tested my download and upload speeds on Charter's and Verizon's SpeedTest site and I'm getting over 500Mb download speeds (see attached).
    .Perhaps it's time to upgrade the Commodore 64 FTP server...
    687 x 333 - 23K
    404 x 197 - 29K
  • greywolfgreywolf Posts: 132
    For me it's not the downloading, it's the actual install that seems to be taking a long time.  2TB SSD, pretty beefy CPU, lots of RAM (128GB). 345MB is taking >60s to install.
    Not sure what to look at.  Ran a chkdsk to make sure everything was kosh.
    To install what? There are various factors that might be involved - a lot of external drives default to using a format that is chosen for compatibility rather than performance, your  security software might be doing checks, if the destination is compressed that will add overhead, if the system is actively indexing the destiantion that may well slow it down, and so on.
  • alan bard newcomeralan bard newcomer Posts: 2,334
    edited October 6
    downloading a new alpha speeds bottom at 10 Mbs and go up to 110 Mbs on a broadband connection from a tmoblie home entertainment package.
    Post edited by alan bard newcomer on
  • jbowlerjbowler Posts: 841
    This is an incredibly old thread; note the speeds in the original post.  There were, from time to time, bad problems but so far as I can see they are all fixed with DIM (I don't use anything else.)
    I see graywolfs post on the 27th triggered the thread back into to existance.
