Adding to Cart…
That sorted it! Thank you for all of your help!
You're welcome.
Well I've run into a glitch none of the male coats work on the female centuar and none of the coats I saved to use on the male will load on the female either keep getting an error message ..
Do not select the "Genesis 3 Female Centaur" or the "Genesis 3 Male Centaur" in the scene tab. Expand that and look for the first parented item for the centaur body, (NOT the geoshell.) I don't have DS open at the moment, so I'm going by memory. I'm pretty sure that will work...
yup been there done that chose Genesis 3 Female Centuar /Female Centuar Body /Female Centuar Tail and then comes Geoshell ,have tried choosing the Genesis 3 Female ,when that threw up the error message I tried ,the Female Centuar Body ....still throws up the error message I can load a texture manually though and the Female skins work on the Male fine so I am confused oh and I've redownloaded the males skins 3 x's thinking there was a update I missed
In that case, I have no idea what is going on. However, I was having an issue where loading a saved scene with a centaur in it would crash Daz Studio, and Tech Support had me clear out my cache. Darned if that didn't fix the problem. I think that's worth a try for you... it may not work, but it won't hurt anything, either. Here's what they told me to do:
I was a bit wary of deleting everything at first, but I found clearing the cache didn't affect anything adversely, and it did fix my crashing problem.
umm only had 2 DS log files in the cache .......and didn't change anything ...oh well I'll just resave the coats ...
I think you should put in a trouble ticket. Let them know you already tried clearing the cache. I'm sure they'll have more and better suggestions.
Would you guys dig something a little different for the centaur?
Oh man that looks amazing rawart
Holy cow, that's some wild stuff.
"This is the right way for go to DAZ marketpalce?"
*drooling with cash in hand* hell yes!
Well I did what you suggested and put in a support ticket ,and was surprised and disappointed with the response " no where on the product page does it state that the Centuar 7 male skins are compatible with the female" and my question was deemed solved.So am I the only one that had this issue with the female skins working on the male but the male skins NOT loading on the femaleor am I the only one that splurged on both?
I have both. I also have IDG Iray Essentials - Daz Horse 2 and Centaur 7, and it loads all the options on either male or female. Not to mention does a much better job on the coat, assuming you're using Iray. It may be I've not had any issues "cross-dressing" my centaurs because I'm using Iray Essentials. I'll bypass that, and see what I can come up with...
ETA: To test this, I loaded 4 centaurs, 1 each centaur complete (G3F and G3M) and 1 each centaur "wearable" on a corresponding G3F and G3M character. One at a time, with all four centaurs, I selected the centaur body and was able to apply all 16 coat presets in both 3Delight and Iray materials.
Remind me again... have you tried uninstalling both centaur products, and then reinstalling?
Yeah, Rawart I like the new model and texture. I usually wait for better prices. Nice work.
I don't have the IDG Iray Essentials ,I have uninstalled the male skins and the female Centuars ,I haven't tried any of the male wearable (aka cothing or armour) on the females .My issue has only been with the male SKINS not applying on the female centuar body. soo I 'll try uninstalling both the male and female Centuars and their skins and reinstall see if that helps ...
okay so uninstalled -reinstalled and still have the same issues and am really confused still the male will take the female textures/skins no problem but the female still is throwing up an error check the log message ....
I have both and the extra pack skins, wanted to be able to really get a mix of centaurs. Now if we are talking the Male G3 hide being use instead of the Female G3 version, that does seem to work.
Centaur 7 for Genesis 3 Male(s), and can apply the coat texture only to the Female Centaur 7 Coat, then the texture from the male to the female.
Now I noticed there were a couple of Centaurs, beautiful in design, nice placement of the hide / skin detail. None the less , they didn't work with the Female Centaurs.
Of the coats which did, including texture packs:
Centaur 7 Male Hides and Breeds
DA Enhanced Iray Materials Presets for Centaur 7 Male
And of course...
Centaur 7 Female Hides and Breeds
Most of the hides did require an update in order to work with both and while waiting for the updates as they came in there was some didn't work but does now.... going on.
Aine for me I have both of the Centuar 7 male and female, the Centuar 7 Male Hides and Breeds ,the Centuar 7 Female Hides and Breeds ,both of which work on the Centuar male ,but the female only loads the female hides if I try the male hides on her it throws up a error message that says check the log ........I've only tried this with the base Centuar figure ,and I don't use Iray so I haven't purchased the IDG's or DA's Iray Material stuff ..........
can somebody tell me if there is a difference in the zip file number of the updated files from the original??Is there a chance I didn't get the update? I manually download and install all my stuff.......
No, there's no difference in the name of the zip file.
You've tried uninstalling and reinstalling both centaur products. Did you redownload the files to reinstall? If not, I recommend uninstalling again, downloading the product files again and reinstall from the newly downloaded files. That will ensure you are working with the latest versions of both products. As you install manually, it is very possible there was an update you didn't get.
yup I have downloaded a fresh zip and reinstalled both of the Centaur7's and both Hides and Breeds .......I give up I'm just gonna create new Materil files for the Hides and Breeds using the female since that works for both figures .Thank you L'Adair
You're welcome. I'm sorry we couldn't find the culprit, though. That's annoying. But I must admit, I don't have a clue what to try next. It's a pain to have to create your own material presets, but perhaps better than spending any more time trying to figure this one out! It shouldn't be too bad; loading both centaurs and applying the materials to the male, then copy/paste from the male centaur body to the female centaur body and the male geoshell to the female geoshell. That should go relatively fast.
Have fun.
Sorry it wasn't working for you, as I could get them to work out. Not sure what it could have been.
I am one to do / handle mainly iRay, but even there, it should have been the same results.
L'Adair, very cool! That would be a faster way to get it over to the other without starting all over again.
yeah the sad thing is I had already create 110 coats from Horse2 for the centuar using the male .......and none of them apply to the female either sooo I have to resave all of them too .Did that while waiting for the female to show up.So once I get done with the needle felted Shih Tzu I'm working on I guess I'll be resaving skins to work on the centuar again
110 coats!!! Holy mackerel... Before you tackle that task, there is something you can try. Have a cup of tea, (or other favorite beverage,) and give me chance to put together a few screencaptures to go along with the steps...
yeah all of SolarisOnLine's horse textures at Rendo ,still have more to go ...I like horses what can I say
Okay, carrie58, here is a quick mini-tutorial for adding compatibility via the Content DB Editor.
Repeat these steps as necessary, (assuming it makes the material presets you created for the male centaur bodies work with the females.)
I hope this helps.
okay so sign me up for the dummies class !! I'm having issues trying to get a screen shot in Windows 10 why do they have to chaange things!! any way when I select the compatability base yeah the list I have is much smaller and is only listing generations and base figures ...which seems weird ...
I use a free utility called Irfanview. Discovered it a very long time ago, and I've used it through numerous iterations of Windows: from Win95, (or maybe Win98... it really was a long time ago,) to Win10. I use it mostly for screencaptures, but occasionally I use it to fine tune compression on a jpg for the Gallery. And I don't have to worry about the latest "greatest" out of Microsoft... I use Win10 on my render machine, but I don't like it. Other than actual rendering, it often feels slower than this older Win7 machine. It definitely doesn't like my wireless Logitech Trackman...
But getting back to the centaur 7, can you add compatibility for the female to one of the material presets for the males? Does it work as expected?
