Transferring Arabella 7 character to Arabella HD: How?
Ok I'm realativly new to Daz Studio. I spent some time morphing a character for Arabella 7. So I just got A7 HD and want to make my character HD
How is this done?
Post edited by naxuam_66429eb97e on
There's nothing to transfer - the HD morph just adds details to the basic shape, it applis to the same figure. HD morphs modify the virtual vertices created by sub-division, they asren't using a figure with a higher base resolution.
Take your character, and dial up the Arabella HD morph. If you like how it looks, great. If you don't, there's nothing you can do to change the HD details, so just stick with what you already had.
In addition to setting the Arabella HD Details morph to 100% you will also want to make sure the Render SubD Level (Minimum) is set to 3 or higher for the character. The HD details don't show up in the viewport very well so you may not notice them until you render and only on scenes where the camera is closer to the character.
Just dont set that subd to 3 until you are ready to render. Lags out your viewport.
The Render Sub Division setting does not affect the viewport.
Oh right.
I use Reality which uses the viewport subd setting. My bad.
