Install Manager cannot find required path
I'm having issues installing a ground shaders package I bought and can't seem to find the solution to this problem with all the other forums i'm reading.  I'm new to this and don't really understand "why" this is happnening so i'm clueless as to how to fix it.  The message:
  • Install Manager cannot find a required path. The package for "Ground shaders" requires that the installed path for "Carrara 8.5, 8, 7.2, 7" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
  • Richard HaseltineRichard Haseltine Posts: 108,764
    Do you in fact have Carrara? If so, is it installed and is it listed in the Applications tab of the Install Manager preferences - click the gear icon at top-right to open Preferences.
  • Wow.  That was it.  Did a search on my computer to find out where my Carrara was located then added the path via the gear icon and the plus button.
    Thanks, Richard!
