G2-G3 Pose Converter can't find files
DDCreateDDCreate Posts: 1,416
I was going through my Product Library and putting together a categorized list of my purchased items so I didn't loose track of any of anything I could use. I came across 2 pose sets for G2M that I tried to convert to G3 but the Converter says the files are empty. (see attached files). I Uninstalled and Re-installed the poses just to see if there might have been a glitch but nothing changed. Has anyone run into this/ knows why this is happening? Any help or advise would be appreciated.
-Thanks!
  • Richard HaseltineRichard Haseltine Posts: 109,314
    Those are folder selection dialogues, not file selection
  • DDCreateDDCreate Posts: 1,416
    edited June 2017
    Okay. Well how do i find the files? This is the path I used  C:\Users\Public\Documents\My DAZ 3D Library\People\Genesis 2 Male\Poses\Powerful Force Poses for Scott 6
    I'm pretty sure that's how I did it in the past too with success.
    I found the Product Help thread but it only seemed to have screen shots/tips/conversation about the Pose Builder Product.
    Post edited by DDCreate on
  • LindseyLindsey Posts: 2,011
    edited June 2017
    If you click on "Select Folder" the poses in that folder should display in the right left window (source).
    The "Select Folder" dialog box does not display pose files, only folders.
    Edit: see soure window correction above
    Post edited by Lindsey on
    Ohhhh I see. I was exceeding the instructions. Was there and I didn't know it, how do you like that? Thanks Lindsey =)
