New Skirt Rig (thank you Wilmap!)
http://www.sharecg.com/v/67408/view/21/DAZ-Studio/New-Dress-Rig
Based on Wilmap's Genesis Evening Wear (used with permission), I have re-rigged the skirt.
This rig is an experimental rig that you can make use of, using the transfer utility, to apply to other dresses.
When you do this, it is very likely you will have to adjust the bones and weight maps to fig whatever dress mesh you are using.
By no means is this rig perfect, and everyone is encouraged to play with and alter it however is necessary.
Thanks wancow. Have downloaded it.:-)
The way the mesh is on this dress, it made it very easy to set up the face and region groups... so thank you, Wendy!!
Oh, thank you and Wilmap very much! :)
