Tiled materials in a cr2?
3WC3WC Posts: 1,147
Just another quick material question. I'm making an outfit for V4, thought I would save a little time on the material textures and just use tiled textures for some zones. Well, okay, but the tiling info doesn't export out to the cr2 file. Is there a way to do that, or do I just need to make a jpg file manually? Only problem with that is it loses a lot of detail when scaled down, or it's going to be about a 26,000 pixel wide texture. I tiled it about 50 times each direction to look right, the tile is 512x512, so you do the math.
  • 4blueyes4blueyes Posts: 153
    Try saving the shader as .mcz or .mc6 in the materials room if you are working in Poser or as a material (or shader) in DS and applying it later to the .cr2 in the scene. The tiling settings in the file should override the lack of tiling in the cr2.
    I think the first obvious question is why do you need it so big? Unless you're doing extreme close-ups or crazy high-rez images at over 25kx25k pixels in dimension, it would be entirely superfluous to go have that much detail.
    If it's simply a case of tiling the same image, then resize your image appropriately before tiling it so that you keep the right general look without going overboard on high resolution textures.
  • 3WC3WC Posts: 1,147
    edited February 2013
    Well, you're right, I did some test renders, and I guess 50 tiles was a bit overkill. It looked right in the preview, but not in the render. So I went with 15. But it still seems that when I scale the tile down from 512 pixels to 137 (2048/15) I lose some detail.
    First pic is one tile, second is 15x15, third is a jpg scaled down and pre-tiled.
    1100 x 792 - 256K
    1100 x 792 - 283K
    1100 x 792 - 180K
    Post edited by 3WC on
