Dance Club
colinmac2
Rendo and DAZ have both failed me on this. I need a dance club, not a strip joint, a DANCE CLUB. Disco-style a plus.
Failing that, I suppose I could put the characters in a public square and call it a block party.
I like the Deco Club product with the Paragon add on, as it comes with a stage, but that might not be your speed. You could use the stage as a 'showcase spot' for dancers, or as a spot to park the DJ. The plus side is that both on sale for real cheap (50-60 cents each) right now (there are also exteriors available), but that sale may end soon.
That being said, there is the Brass Pole, which is a converted fire station. Despite the name, it's configured more like a regular bar with dance floor. It has a mirror ball too, with some DJ equipment.
https://www.daz3d.com/the-brass-pole-nightclub
You may be able to change the 'dance floor' area over to an emissive surface, to create that 'lit dance floor' look, and maybe add some mirrors to a wall or two to make the room look bigger using plane primitives or selecting a particular wall, if the product has the walls separated from each other. You could also add a false ceiling in a similar manner that is either an emissive surface or a mirror, above the dance floor, which might be more in line with that classic disco look..
Just what I needed-- THANKS!! -- The Brass Pole will work perfectly!
