Winter Castle from Stonemason problem
MusclemanMuscleman Posts: 3,100
Hello I buy the Winter Castle from Stonemason but anytime I try to render it I get that......why it's possible? Where I make the error? ( yes, I use Iray)
  • ThatGuyThatGuy Posts: 797
    Hmmm...I don't seem to have that problem.  I did nothing to it (the scene), but add Skies of Iradiance for lighting and then pressed render (Iray).  Maybe you need to re-download/re-installed the product.
    994 x 698 - 364K
  • TaozTaoz Posts: 10,285
    Works fine here too.
  • MusclemanMuscleman Posts: 3,100
    Thanks, I will re-insall
    Is it possible a hdri ground interfering with you scene?
    I just loaded and click render....for see how it' look.....but....still blue!
  • K-GatorK-Gator Posts: 2
    I had the same problem, and I solve it by applying Iray Uber Base and loading the normal maps again.
