Bone won't go invisible...
ScavengerScavenger Posts: 2,674
I have a bone in a model that I'm trying to turn off the visibility of.  It isn't locked. It will toggle visibility in the paremters..there eye turns off and on...The face group that makes up the bone will go visibile and not as I toggle that...but not when I try to do it from the bone.
Anyone have ideas to fix it?
  • Richard HaseltineRichard Haseltine Posts: 108,992
    The visible button and the eye icon in the Scene pane should be the same, so no idea.
    is the geometry assigned to multiple bones?
  • ScavengerScavenger Posts: 2,674
    I don't think so..how would I check that?
    In joint view...the bone triangle goes away and not when the visible is toggled...but  still can't figure out the problem with the geometery... (chest has the same issue...the others don't)
    597 x 592 - 52K
    587 x 531 - 38K
    571 x 555 - 46K
    266 x 38 - 7K
    Well, I checked the original Poser obj...that works fine...and converting it to gerneral weight mapping is where whatever goes wrong happens.
