Genesis fitting issue with clothing
corrosecorrose Posts: 7
Hello all,
I was wondering if there was a solution for an issue I keep running into. I'm hoping there is a setting, or package that I can purchase to fix it.
Take a look at the attached images. With the females, basically any kind of top whether it be a dress or shirt is very very curve and form fitting, to the point where t-shirts look un-natural on the females.
I was hoping to find a solution that would allow for something like the circled image, where the fabric acts how it would naturally on the upper body.
Any thoughts?
    There is this in the Store jere, but I don;t have it, so I couldn't offer an opinion : http://www.daz3d.com/clothing-cleavage-modifier
    If you also have Hexagon, you could send the clothed character to Hex, and create a morph to fix it there.
  • TotteTotte Posts: 14,901
    edited February 2013
    Hello,
    there is a fix for that here: http://www.daz3d.com/clothing-cleavage-modifier
    Hope this helps!
    / Totte
    Edit: posted the same time as Jimmy.
    Post edited by Totte on
  • Scott LivingstonScott Livingston Posts: 4,348
    If you want to give the Hexagon method a try, here's a step-by-step: http://www.daz3d.com/forums/discussion/12921/#188888
    Also, you might be interested in this forthcoming product by SickleYield: http://www.daz3d.com/forums/discussion/15492/
    And a current Breast Fixer here.
  • edited December 1969
    Can it fix the fit of Gen3 dresses on Genesis? I mean, solving problems like here... http://mcmxc2.deviantart.com/art/Comparison-328434555
    Not on Gen 3, no. It works by adding custom morphs and that's an Autofit issue.
    So, there's still no solution for the fitting of Gen3 dresses on Genesis?:(
  • Richard HaseltineRichard Haseltine Posts: 109,366
    Clothing Cleavage modifier works on Genesis, it doesn't matter where the clothes came from. I would assume the same is true of SickleYield's set.
    Not so, unfortunately. The CCM is a morph for Genesis and mine is a separate conforming item with FBMs in it. It's not optimized for conversions. I'm fairly sure the CCM won't fix that issue either giving the amount of distortion in the pics, but it's more worth a try for Gen 3 converted items.
    If it's just a morph, I don't think it will work too:/
  • corrosecorrose Posts: 7
    I bought both yesterday to try out. As much as I love Daz products, the Daz one IMO is pretty crappy, most settings on genesis look like a railroad spike is pushing the shirt or top outward from the chest, none of the sliders give smooth transitions, and all give some variation of the sharp object pushing forward.
    The one from Renderosity is much better, I wish it had a little more flexibility to have the shirt more flat in front like in the example I posted first, but all in all it is worth the $10.
    A couple of renders I did to show how it looks
    543 x 400 - 28K
    589 x 746 - 45K
    Why not? If you mean the Clothing Cleavage Modifier, each is actually two morphs - one that fills the cleavage in, that is set to autofollow so that it gets transferred to the clothes, and one that reverses the change, that isn't set to autofollow and so doesn't get transferred. As a result the figure appears unchanged while the clothing is modified.
    ...uhmmm... I will think about it...
