v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
15678911»
  • mCasualmCasual Posts: 4,607
    edited December 2014
    RAMWolff said:
    Nice and clean!
    who knows maybe i'll have time to build an xmas tree using mcjBuilder's and post the script before xmas
    in the 1990's i think, i made a tree using POV-Ray
    i didn't really try to make mcjBuilder's "language" similar to POV-Ray but maybe i should have
    or make mcjBuilder's language compatible with the Daz Studio script language
    ( i have a secret project of turning mcjBuilder's into a real-time-previewing plugin )
    Figure 4 - Tada !! corrected the triangulation issue
    Fig 5 texture by http://nobiax.deviantart.com/gallery/?coffset=30
    someday someday i may add a "quadrangulate" option for the "caps" because they are better suited for UV maps
    1920 x 1080 - 290K
    1920 x 1080 - 605K
    1920 x 1080 - 372K
    1920 x 1080 - 472K
    1920 x 1080 - 537K
    Post edited by mCasual on
    as you can see here, the UV maps produced by mcjBuilder are not faulty <<---- <span style="color:purple">That is so not true !
    if renderers were using proper UV projection/interpolation methods and numerical precision
    the rendered textures would not have stretch marks
    nah ... it's my fault i have to fix this !!!
    ( because just now i tried planar UV mapping and ... no stretch marks )
    figure 2, the object built using mcjBuilder but re-planar-uv-mapped in Blender
    and rendered in Daz Software Render
    texture maps ( including a Normal map and a specular map ! ) by http://nobiax.deviantart.com/gallery/?coffset=30
    Figure 3 Ah HA!
    oops sorry i shouldnt shout in the forum :~
    i was using un-shrunk vertex positions to build the "caps" UV maps
    and shrunk vertex positions ... as vertex positions
    and figure 3 shows that when shrinking is minimal, texture issues disappear
    1920 x 1080 - 562K
    1920 x 1080 - 742K
    706 x 702 - 191K
  • RAMWolffRAMWolff Posts: 10,363
    It still amazes me that looking at how the verts are set up to conjoin in such a drastic way instead of the points being spread evenly can give such a nice tiling effect when a tile is applied to the surface. I guess I still don't understand how that can be!
    i'm happy because initially i thought the inevitable consequence of having them ( what's the word? ) triangles ( no not degenerate triangles ) was that the textures would be distorted
    shown below, the shrink command was used and the Lid's UVs are perfect!
    though one drawback of having non-welded caps is that displacement maps are harder to use
    1920 x 1080 - 1M
    now i think i can resume the big mcjBuilder test wherein i recreate the Gothic'ish movie set used in many kpop videos
    like this recent one https://www.youtube.com/watch?v=tkli82UgSVA
    after long and arduous google search expeditions i found it !
    the company that designed and built the set used in many kpop videos
    http://blog.naver.com/bow_design/40199354503
    1920 x 1080 - 899K
    in mcjBuilderA9 there will be an "include" command
    which has the same effect as copy-pasting a block of commands from a txt file into mcjBlender's 'path' editor
    the source files will be required to be in a specific folder titled ''include''
    so if someone devellops nice universal code to create rectangular frames ( i did )
    then making a frame could be as simple as typing
    include frame.txt
    frame 16 9
    and you'd get a 16" x 9" frame using the default 'square' profile ( see fig. 2 )
    or if you type
    include frame.txt
    Profile FrLegacy1
    frame 16 9
    you'd get a 16" x 9" frame using the 'FrLegacy1' profile ( see fig 1 )
    then if you learned what the moldSize command does ( see fig 3 )
    include frame.txt
    Profile FrLegacy3
    MoldSize 1 .34
    frame 16 9
    figure 4 - i was pondering ways to let mcjBuilder make the columns but in the end i'll probably make a morphing prop for that
    fig 5 improved base
    1920 x 1080 - 724K
    1920 x 1080 - 686K
    1280 x 720 - 825K
    928 x 640 - 193K
    1280 x 720 - 263K
    this "podium" object,
    built using the upcoming mcjBuilderA 9.0
    and the 2 new commands " setShrink" and "include"
    the "defaults.txt" file contains all the settings following a click on the "restore defaults" button
    include defaults.txt
    Profile carre20
    MoldSize 16 16
    RotateX -90
    setshrink .2
    Ring
    endCap
    setshrink .1
    Ring
    setshrink 0
    move .1
    Ring
    move .1
    Ring
    Move 2
    Ring
    move .1
    Ring
    setshrink .1
    move .1
    Ring
    setshrink 0
    setScale .82
    move .4
    Ring
    setScale .80
    move .1
    Ring
    move .1
    Ring
    move 1
    Ring
    move .1
    Ring
    setShrink .1
    move .1
    Ring
    setShrink .2
    Ring
    endCap
    1920 x 1080 - 855K
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,249
    I'm still stunned by the work in this thread! Very creative and inspiring work.
    I made these frames in just a few minutes using this recipe ( see below )
    a pack of morphing door frame props will be posted today under the ( google-search-friendly ) name mcjDoorFramePack
    var width 82+8
    var height 208+8
    closePath false
    profileUnits cm
    moldSize 12 2
    pathUnits cm
    tread 1
    MoveTo width/2 0 0
    SetRot -90 0 0
    Ring
    move height
    SetRotZ 45
    SetScaleX 1.41
    Ring
    Move .1
    Ring
    SetScaleX 1
    SetRotZ 90
    move width
    SetRotZ 90+45
    SetScaleX 1.41
    Ring
    Move .1
    Ring
    SetScaleX 1
    SetRotZ 90+90
    Move height
    Ring
    1920 x 1080 - 989K
  • ElowanElowan Posts: 388
    Haven't found it yet
    it's in this thread here
    http://www.daz3d.com/forums/discussion/55168/
    i thought i could limit myself to 40 frame props
    but to give a more complete set, it has become 240 !!!
    so it's taking a bit longer (as always ) than planned
    I'm not finding an active link
    edited May 2017
    minor update minor update minor update minor update
    i dont remember if it was always like that but mcjBuilderA was not loading meshes in "silent" mode and you had to re-specify the Daz import scale everytime
    the new version in the package mcjBuilderA_Beta_8_1.zip (173k) solves this issue
    https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera
    Note that i also fixed this issue for mcjPathTube
    800 x 800 - 448K
    edited September 2017
    MAJOR UPDATE!! Version 9.0
    new commands let you insert meshes contained in .obj files in your buildings
    https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera?pli=1
    example: the code for the rainbow colored DNA thing
    PathUnits cm
    radius 0.01
    Tread 1
    loadobj drop i:\z\halter.obj
    nomatobj drop
    repeat 16
    material "mat"+count
    dropobj drop
    rotate 22.5
    moveY 3
    repeatend
    the S - shaped twirly things ... made with mcjBuilderA, the gold and the white rims ... also ... the DNA multicolored prop ... also made with mcjBuilderA v9.0
    800 x 800 - 54K
    960 x 540 - 109K
    960 x 960 - 250K
  • SixDsSixDs Posts: 2,384
    Thank you, Jacques! I really, really, really do need to make some time to devote to playing with all your wonderful toys.
    welcome
    for simple mouldings ( the impetus for this was to create handrails for the castle's stairs ) the number of commands to learn is small
    so for the frame of this bed foot the code was mainly the commands : radius, ring, turn, hardturn
    Profile	FrLegacy1closeprofile	onClosePath	onInvertNormals	onstepangle	15/2rotateY	90ringmove	84hardTurn	90move	18ringradius	15turn	-45radius	15turn	180radius	20turn	-90radius	23turn	90hardturn	-90turn	90radius	20turn	-90radius	15turn	180radius	15turn	-45move	18hardTurn	90ring
    800 x 800 - 136K
    improved code for the bed head frame
    here i used the current position of the extrusion nozzle to very precisely stop at X = 0 , the mirror line of this shape
    note that you dont have the "princessbedsidecen" extrusion nozzle in the mcjBuilderA distribution, so use another one
    Profile	princessbedsidecencloseprofile	onClosePath	onInvertNormals	onstepangle	15/2rotateY	90ringmove	84hardTurn	90move	18ringradius	15turn	-45radius	15turn	180radius	20turn	-90radius	23turn	90var	len	0set	len	curPosX*sqrt(2)move	lenrotate	-45setScaleX	sqrt(2)ringsetScaleX	1rotate	-45move	lenturn	90radius	20turn	-90radius	15turn	180radius	15turn	-45move	18hardTurn	90ring
    800 x 844 - 70K
  • mindsongmindsong Posts: 1,736
    this is kind of like a virtual CNC machine, with a control language and all - and no high-speed router bits to blow up with erroneous commands. Way too cool.
    not quite sure how I'll use this yet, but when I get there, I'm certain I'll be praising your name (and pressing the 'donate' button). thanks in advance for the update.
    cheers,
    --ms
    thanks! eventually i will convert it into a plugin much faster and the syntax will be basically like javascript. The current language is tricky when it comes to things like blank spaces and tabs
    cheers,
    --ms
    1920 x 1080 - 645K
  • MythmakerMythmaker Posts: 606
    Just dropping by to say, nice to see MCasual continues to make awesome and fun and inspiring things happen in Daz Studio!
