[Resolved] Personal folder in DS
Fuerchan
Hi,
To find files more easily from the software (DS), is it possible to create a personal folder, in which I can install all the accessires purchased and save the poses I created ?
If so, what is the procedure?
Thank you :-)
F.
Post edited by Fuerchan on
By default DS uses the \Documents\Daz 3D\Studio\My Library folder for saves, but you can use a different one if you wish - just change the destination in the file dialogue. Or are you looking at the database views, with items appearing under Saved Files? I don't think there's a way to chnage categorisation on saving, but you can certainly change (or add to) the categorisation once the file exists.
Hi,
I installed a garment in: C: \ Users \ PCH \ Documents \ DAZ 3D \ Studio \ My Library \ Accessories
In DS I find the folder "Accessories", but inside I have only the installation files of the garment "Runtime". Nothing allows me to dress the prescription (Genesis).
I looked everywhere (elsewhere) but nothing.
Does it make a "link" in DS with the installation folder?
If yes, how ?
Thank you
F.
If it has a "Runtime" folder it is Poser format and cannot be made a sub-folder in you Studio format library. In Windows Explorer drag the "Runtime" folder up one to be in your "My Library" folder then look for the files in the Content Library pane under Poser Formats.
Hi,
Ok, the runtime file must be at the root of My Libary, it works. So I will not be able to use any folders specific to each accessories.
Thank you :-)
F
