Anybody make a "Wear them all" for shoes?
in The Commons
So yeah, um...shoes are still an issue. Sometimes I can get away with a pose to put the feet in the proper position.
For closed shoes I can sometimes get away with making the feet invisible...
But those damn open-toe shoes....
The shoes don't even get close to being slipped on - or fitting - way worse than the poke through I used to get.
Has anyone solved this with a product? (aside from me doing a whole lot of jiggery)
It you're talking about fitting V4 to G3F, it needs two steps.
First autofit V4 to G2F and save as a Wearable Preset.
Autofit that Wearable Preset to G3F and save it as a Wearable Preset.
This "usually" works, but not always. IME there are some shoes that just don't work from V4 to G3F. Not a large percentage but some.
Ahh, okay thanks I will explore that.
High heels will always be a problem. Flat shoes/flat boots generally work ok most of the time. But yeah, high heels/stilettos are a problem.
I have the same problem with gloves, when trying to port older gloves to newer figures. Gloves are trickier though, because of finger positioning. Yes, I can attempt to position each finger manually, but that's a pain, and often gets messed up again if you apply a new pose to the hand/figure.
