Backing up Daz studio settings?
hacsart
Is there a way to backup the program settings for Daz Studio? Had a Windows crash, and lost all interface customization as well as author info, etc? Studio 4.9 on Win 8.1
Thanks!
You can save your layout from Window>Workspace>Customise. You can also back up the C:\Users\YOU\AppData\Roaming\Daz 3d\Studio 4 folder, and the C:\Users\YOU\AppData\Roaming\Daz 3d\cms folder for the content database.
you can also save the specific registry settings which is useful, but if you're not familiar with it - potentially risky.
Thanks - restored the appdata folder form a backup and that got most of it.. Will look at what is stored in the registry...
Rob now has some sample scripts that will help with backing up and restoring:
backup just the layout files
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/file_zip_compress_each/start
restore layout files
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/file_zip_extract_each/start
There are also a couple for backing up/restoring folders as a whole
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/file_zip_compress_all/start
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/file_zip_extract_all/start
