v4.x Scene Builder.
Has anyone else have issues using the Scene Builder in DAZ Studio.
Since v4.5 I have been having issues the builder not finding the other supported files. I have reported the issue to DAZ, becouse there were no horizontal scroll bars when you added more files. The vertical bar worked fine.
DAZ support claimed it a bug and the fix was to create the Wizard.
They have encrypted the Scene Builder code to try to fix the issue except the .json. Modifying the .json file and relaunching the software does not correct the issue.
The only thing I have did to correct the issue is to add the files to the /SceneBuilder directory. That just waste space and the shortcuts do not pick up the files.
I have tried by install default values in DAZ Studio, custom install locations, and in the default Install Manager values.
Has anyone have a workaround for this issue.
OS versions used: Windows 7 and Windows 10.
I have even tried Windows Server 2008 and later. Does the same thing.
  • Richard HaseltineRichard Haseltine Posts: 108,773
    So what is the error you are getting? Do you have the various Starter Essentials packs installed, as well as the Scene Builder package?
