Centaur 7
1810121314
  • ALLIEKATBLUEALLIEKATBLUE Posts: 2,983
    edited May 2017
    Ildanach said:
    I have a feeling there will be a female centaur soon, featuring Ophelia 7 like they did with Dante 7.
    Yup but being the Dazzling Dazes that we are, we will create our own until she becomes available.  Just a quick Centauride just to see how difficult it would be. Not a warrior one though, more like a supermodel.
    717 x 921 - 660K
    Post edited by ALLIEKATBLUE on
  • L'AdairL'Adair Posts: 9,479
    edited May 2017
    How did you create your centauride? GenX2, Or something else?
    Anyway... GenX2 with the G3 Addon makes it easy to give Centaur 7 the female form, but I'm really looking forward to the female version of Centaur 7. Fitting clothing to the horse geograft is hard enough without going cross gender! I spent more than a day making the top to the Chevaleresse Armor fit my centauride, only to watch it all fall apart the moment I tried to pose her. Smoothing caused unexpected issues, too. In th end, I used the vest and armbracers from Dark Whisper. And because Dark Whisper was created for G3M, it fit and moved beautifully with the pose. (Render posted earlier in this thread.)
    But... with the relative shortage of great male clothing, (which has improved over the past year+,) it's still difficult to clothe our GenX2 centaurides...
    Post edited by L'Adair on
    I just used GenX and imported the morphs.  The one in the picture is Ana Sofia (https://www.daz3d.com/fw-ana-sofia-hd-for-victoria-7 ) and the top was a simple one, from forrest Fawna (https://www.daz3d.com/forest-fantasy-fawna-for-genesis-3-female-s ) It was late so I didn't try anything to difficult clothing wise but I have Wear Them All so maybe that made the clothing fit easier. But it was only a bikini top so I will see how a more substantial garment fits as well.
    edited May 2017
    I recently put in a trouble ticket because DS keeps crashing when I try to load one of my previously saved centaur projects. The full text of the trouble ticket is below. I'm bringing this up to see if anyone else is having a similar issue.
    This problem seems really weird to me. Attempts to load saved scenes that include a Centaur 7 figure are crashing DS. But it's not consistent.
    Sometimes the file will load, other times it crashes the program. Sometimes I can open it in the beta but not the release, (both are 4.9.3.166,) and other times it's the other way around... unless I can't open the file in either one.
    Before I realized the issue was Centaur 7 specific, I even tried reinstalling the release version of DS. I've restarted the computer and hard reboot it, but nothing seems to make any difference. Sometimes I can add a centaur 7 to a new scene, and then Open Recent a scene with C7, other times, that will crash. Same thing with using Merge. As far as I can tell, the only thing consistent is it's only every happened when there is a C7 in the scene. I've opened a number of older scenes, from earlier in the year to the last scene I did that did not have C7 in it, and none of those files caused the crash.
    If you look at my 2017 Iray Gallery ( https://www.daz3d.com/gallery/#galleries/1429281 ) you'll see I've completed and uploaded three images using Centaur 7. I didn't notice the crash problem until the last of the three, Sagittarius, but if I recall correctly, I didn't shut down the computer or the program until the other two were complete, (mainly because I was allowing the scene to render while I slept. But with Sagittarius, I wasn't at a point to start rendering when I went to bed, so I shut everything down. It was the next day when I ran into problems loading the file. (I finally managed to get the file to load in the beta, so I finished what I started while I had the chance!)
    Since I completed Sagittarius, I've been trying to determine what was the problem, and ultimately came to the conclusion there was something about Centaur 7 that Daz Studio doesn't like, on this computer.
    I have saved several crash reports and I'm attaching a couple of them.
    I should mention, I keep my render computer offline except when transferring files between it and this computer. I almost never use it to go online, the exception being when I need a plugin to be able to "phone home" to activate. The only programs installed are from DAZ or Adobe, except for Blender, (which I have yet to learn how to use,) and one or two utilities, like GPU-Z. The only broswer, which I do not use, is the included Edge.
    While this might be hardware specific, it does seem very odd that it only happens if there is a C7 in the saved file. After it happened the first time, I started to recreate my "Sagittarius" project and saved incrementally along the way. Impatience won out, and I tried opening the original file and finally got it open without crashing in the beta. Since then, I tried opening the incremental files, (there are five of them.) So far, I've been able to open the first and second file without a crash. The third file might open, or it might crash DS. The fourth and fifth always crash DS.
    If anyone else is having this issue, no matter how infrequently, it would be helpful to open a trouble ticket and share what you can with tech support. And of course, if I'm the only one who is having this issue, than I can look to my computer for the cure.
    Thank you for taking the time to read this post.
    -Anita
     aka L'Adair
    ETA: It looks like Tech Support found my problem, and it was specific to my computer. However, if you are reading this because you are experiencing the same thing, the apparent solution on my machine was to delete all the files in the dson cache folder. (C:\Users\username\AppData\Roaming\DAZ 3D\dson\cache) There will be a data folder and inside the data folder are a lot of other folders. Don't worry, they will be repopulated as you use the various products.
  • carrie58carrie58 Posts: 4,126
    Interesting image Angelreaper ,is it just me or do the wings look backwards?
  • Silver DolphinSilver Dolphin Posts: 1,640
    Nice creature creation. Just a thought but you might want to make the body of the horse a little bigger if possible. Great looking Centaur Pegasus.
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,612
    @carrie58 thanks that's one of the posing morphs for the wings kinda of a swooping down pose I think or flying back backwards up after an attack maybe? Kinda lifting up behind oops just loaded him I was looking at different angle yeah they have rotated backwards funny when setting up they were facing right posing the wing morphs must've rotated them and I didn't notice nice catch
    @Silver Dolphin thanks yeah I did try to do that actually got the pro so got the different breed sizes didn't seem to want to do that tried dialing down the humanoid part but was losing much of the morphs I've saved him as a charcter so I can try and work out something hopefully can get the balance right maybe if I add another centaur base make larger parent it and blend the two think he has potential so I'll keep playing around
    How much longer until we get the Centuride for G3F ? I is getting sad waiting!!
  • ChangelingChickChangelingChick Posts: 3,378
    edited May 2017
    Post edited by ChangelingChick on
    Yay!
    So I'm wondering, DAZ, if the "Centaur 7 Female Hides and Breeds" animal hide will also work on the male Centaur 7 and vice-versa? They are both "Centaur 7" and the 16 total hides, between the base figures and both "Hides and Breeds" products, include all the hides for the DAZ Horse 2...
  • JOdelJOdel Posts: 6,322
    For the most part, probably. But with the female centaur we finally have a mare morph for the horse portion, whereas the DAZ Horse2 had only a gelding morph. It might make no difference, it might make some difference in the relevant area.
  • NikisatezNikisatez Posts: 88
    Redz said:
    Finally got a chance to play with the Centaur. This is RawArt's Rogan with NGS Anagenesis shaders.
    http://www.daz3d.com/gallery/images/358316/
    SaveLove this! I wanted to make a hair/mane like this, with added feathers, but the Daz team weren't interested. maybe I should do one for my store.
    @Nikisatez that sounds like a awsome hair idea and would be very popular don't get why d wouldn't be interested
    probably doubling up on same horse textures but there is enough other goodies in pro to not worry about that too much for me just waiting for store to settle in case of glitches and see if we get another banner bonus for buying centaur 7 pro still getting this pro regardless
    No, you're not doubling up on textures. You'll get 8 more DAZ Horse 2 Pro textures modified to work with Centaur 7.
    say what?????????? Shall I start a petition telling daz we WANT a hair like you described?? Cos I damn well sure will start that! I want the hair you mentioned!!! dammit, I'll buy it from you privately if daz won't take it. Ridiculous!!!
    Nikisatez said:
  • NathNath Posts: 2,989
    Nikisatez said:
    I'd totally get that hair.
    ok then. I'll see if I can fit it in somewhere in my schedule :D
  • HorusRaHorusRa Posts: 1,665
    edited March 2019
    Post edited by HorusRa on
  • Rod Wise DriggoRod Wise Driggo Posts: 2,333
    Yeah, was hoping for an orange banner for owners of the G3M Centaur at least.
  • RedzRedz Posts: 1,459
    Thank you :) I assume Daz knows what sells, but a feathered mane sounds epic. You should definitely make it. In the meantime, I made this one available as a freebie https://www.daz3d.com/forums/discussion/168421/free-conforming-mane-for-centaur-7-and-genesis-3-male
    I also was hoping for an orange banner. Will sit on this one for a bit.
    edited March 2019
  • DestinysGardenDestinysGarden Posts: 2,553
    L'Adair said:
    Yay!
    I know this one, and the answer is yes. The male hides and female hides are interchangeable. One preset will apply to either one. On a related note, if you already have my IDG Iray Essentials for the Daz Horse 2 and Centaur 7, the male hides in that set will apply to the female centaur already, and the free update to add the female hides for both centaurs is working its way through the system right now.
  • Diggin' Centauride 7 (Yes, I know that's not what it's actually called, but I'm sticking with mythological accuracy, lmao) a lot more than I thought I would, haha. Great compliment to Centaur 7, too.
    The outfit selection is quite nice, too. Mythos in particular is gorgeous.
  • FerretmaniaFerretmania Posts: 883
    Nikisatez said:
    +1 I would love a hair like that too!
    Of course I'm getting Centaur 7 female, but she looks weird to me in a dress for some reason.
  • LlynaraLlynara Posts: 4,772
    L'Adair said:
    Yay!
    @DestinysGarden Yay! I'm so thrilled to hear this! I love your shaders, they are fabulous. Just knowing these will work for the Centaur Female and you've got more coming is enough reason for me to take the plunge on today's release.
    @nikisatez I'd love to see a feather mane! Makes me think it would go well with a kit bash of BadKitteh's beautiful bird outfit (can't remember the name of it at the moment)
    @Redz Thank you so much for this beautiful freebie!
  • Blood-PawWerewolfBlood-PawWerewolf Posts: 338
    edited May 2017
    Why are those 2 at 30% off when everything that was released today is 51% for the Centuar 7 Female? Is it a store glitch or is it supposed to be like that?
    (mind my poor grammar, my brain hasn't fully awoken yet)
    EDIT: 3 items if you include the Double Trouble Braids hair
    2048 x 1536 - 5M
    Post edited by Blood-PawWerewolf on
  • CrescentCrescent Posts: 334
    Most of the Centaur items are DAZ buyouts, so combined with the DAZ Plat Club discount, the total percentage discount is 51%.  The 2 items you're calling out are PA items, so they're the usual 30% off.
