Starfire hair! :) I needs it.
RKane_1RKane_1 Posts: 3,039
edited September 2018 in The Commons
Looking for this hair or the closest proximity to it.
Wish me luck. :)
Post edited by RKane_1 on
«13
  • ScavengerScavenger Posts: 2,677
    Find the top part that you like, then with scaling and instances build the back.
    Haven't seen anything like Starfire hair, sorry to say.
  • RobotHeadArtRobotHeadArt Posts: 917
    I don't think there is hair like that because it would be a nightmare to rig.  If you were to go the route Scavenger suggested, you might want to look at the hair from StudioArtVartanian at Renderosity since there's a few big volume/long hair styles that you could try combining together.
  • TaozTaoz Posts: 10,346
    Maybe this:
    Curly Hair for Women  -  https://www.daz3d.com/catalog/product/view/id/05302
    edited May 2017
    Just tried it on G3F, you can actually make it very long with the morphs, the downside is how it looks from the side but I guess it can be fixed in Hexagon or something. If you check "Show Hidden Properties" it looks like there are more morphs showing up.
    789 x 870 - 59K
    Post edited by Taoz on
  • RedzRedz Posts: 1,459
    As somebody mentioned some of Studio Art Vartarian's hairs could get you close.
    https://www.renderosity.com/mod/bcs/sav-aphana-hair/105056/
    https://www.renderosity.com/mod/bcs/sav-semiramis-hair/102152/
    You'll probably need to heavily postwork the style to get it to look right. Kory has a ton of hair. That said I have seen her in the gallery done by other artists so if I see the image again I'll make sure to note what  hair is used.
  • nicsttnicstt Posts: 11,715
    This one might work: https://www.daz3d.com/antonia-hair
    Can make it very long
  • RawArtRawArt Posts: 6,216
    I used the "Streaming Hair" by Smay for my starfire pic.
    It doesnt have the curls, but has nice movement morphs and materials
    https://www.daz3d.com/streaming-hair-for-genesis-3-female-s
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    edited May 2017
    Olena Hair for G3F looks like it'd accomplish what you need below the neck:
    Then you could just double it up with some other hair to achieve the look you need up top.  Say the aforementioned Curly Hair for Women
    Sylphiad Hair also looks like it has sufficient curls for your purposes:
    You can often lengthen the hair using hidden parameters, if the 'built in hair morphs don't include hair lengthening.
    Post edited by tj_1ca9500b on
  • RKane_1RKane_1 Posts: 3,039
    I need something also to approximate the bangs and the buildup ABOVE the scalp. Was actually thinkinking of making a morph to her skull that would mishap her skull but move the hair where I wanted it. *chuckle*
    edited May 2017
    Twilight Hair for G3F has a lot of volume up top.  You could lower the 'y axis' into the skull to bury some of it inside another hairstyle.
    Haven't tried it, but I have some longer hairstyles, maybe I'll give it a go and post a render.  The nice thing about hair is that in a number of cases you can blend two hairstyles together.
    Post edited by Chohole on
    Ohhh...I like this one...in my cart :)
    edited May 2017
    OK, this is a quick kitbash, but it should give you some ideas...
    Here I've combined two instances of Twilight Hair, with some coordinate adjustments to the 'head' subdivision, scaling adjustments to 'bury' parts of the Twilight hair inside the scalp/behind the eyes, and some volume morphs and such.  The two instances are slightly offset from each other to provide more volume.  I've also added an instance of Free Spirit Crimped Hair and an instance of Free Spirit Hair.  Obviously, the hair follicles need to be adjusted to clear the arms, but it shows off well enough how you can achieve that 'Big Hair' look with some creative combining of multiple hairstyles.
    My kitbash here is far from perfect (colors need to be matched, FS Hair instances need more volume adjustments, etc.) and I'm not looking to design a Starfire character anytime soon myself, but it should point you in the right direction...
    889 x 500 - 81K
    Greetings,
    What about Prae Avenza hair?  It's got the curl and the body...
    --  Morgan
    The bangs are not quite right.
    I was thinking of using SAV Aphana hair bnut having horrible times with figuring out the handles and how they work once confomred to a Gen 3 figure.
  • zombietaggerungzombietaggerung Posts: 3,942
    edited May 2017
    You'd probably be better off just parenting it to your figure's head so it doesn't lose it's rigging. At least that's my experience with V4 hairs on G3.
    Post edited by zombietaggerung on
    edited May 2017
    Thanks, zombietaggerung . When I get off work, that is what I intend to do. When conformed, the hair handles either do nothing or cause the hair to EXPLODE!
    I think I needs very curly hair but not a tight curl, ya'know? And long. Very long
  • cherpenbeckcherpenbeck Posts: 1,418
    Post edited by cherpenbeck on
    Both are gorgeous but a little too straight. Don't suppose their is any easy way to put a ripple in the hair, is there?
  • kyoto kidkyoto kid Posts: 42,408
    ...Aphana hair looks like it might work for my Merida project.  Thanks.
    i like that hair but I need those bangs! :)
  • Gr00vusGr00vus Posts: 372
    Check out hr-137 or hr-144 by ali at rosity. I think hr-137 will get about as close as you can get with off the shelf hair for what you're doing.
    A problem I've experienced with hr-137 is that the transparency map isn't super - the hair can end up looking like rectangular strips in certain lighting situations.
    Post edited by Gr00vus on
    I like the HR-144 but I think layering that with Olena hair is going to be my best bet. I may actually have to rig a lengthy hair chain together to get the flowing hair behind her flying figure.
    @RKane_1 How about this one I ran across recently? I remembered this thread.
    https://www.renderosity.com/mod/bcs/sav-zero-gravity-hair/108061
    Nice one, Paintbox! :)
    Does anyone know if there is an EASY way to add curl to a pre-existing hair set?
    if you use a modelling app: Blender, Zbrush, Hexagon and many others, it is possible; whether it's what you want, unknown. :) Not easy, but certainly not difficult.
  • galattgalatt Posts: 230
    I did this one https://orig00.deviantart.net/b04b/f/2016/305/3/1/halloween_2016_by_gx_9901-dan17em.png By combining the SavAlpha hair from Rendo and applying the hair texture to the flame trail from https://www.daz3d.com/maximum-overkill
    Nice, Galat!
    My quest continues. :)
    I see a lot of hair that would work for the back but those bangs are a little ... unique. Symetrical with a curl going in at the bottom.
