bone resistance to movement and mouse setting
hi,,i need to understand how to adjust the bone resistance to movement,,,,or ...after i have turned my mouse setting one notch from lowest in windows and the like ,
what do in need to adjust so the individual parts or bones dont run off in circles at the slightest touch movment of the mouse,,, thanks
What are you doing, dragging with the Universal tool? Or dragging a slider, or a gizmo?
Sounds like limits of bone rotations in parameters are disabled.
universal tool gizmo,,, which one should i use and how to set it up? thanks
What do you mean, which one should you use?
If your figure in the scene had somehow the bone rotation limits set to OFF, then you should set them ON again. Therfore select the figure root node in the scene pane, right klick and choose "Select Children" so all bones of the figure are selected. After that go to main menu Edit > Figure > Limits > Limits On (Rotation). Now the bones can be rotated with any tool like the universal and will bend much slower within the given rotation limits angle.
Edit: Now I remeber there is also a so called Nudge value in the Parameters for every Propery that defines the steps width - how fast the slider can get moved with the mouse or jumps left right if you click the minus and plus signs at the beginning and end. But this dosnt affect the movement speed of any of the gizmo tools like the universal tool.
