What IS Iray VERBOSE? It's killing my renders!
Recently I began seeing these messages when I go to render:
Iray VERBOSE - module:category(IRAY:RENDER): 1.8 IRAY rend progr: CPU: Processing scene...
Iray VERBOSE - module:category(IRAY:RENDER): 1.7 IRAY rend progr: CUDA device 0 (GeForce GTX TITAN X): Processing scene...
Iray VERBOSE - module:category(IRAY:RENDER): 1.6 IRAY rend stat : Geometry memory consumption: 3.28598 GiB (device 0), 0 B (host)
I have NO idea what they mean and I'm sure I haven't seen them before, but suddenly simple renders are taking FOREER.. IF they even decide to render what's in the scene AT ALL! All I get is the background and nothing else, after 10 or more minutes of waiting. It is a VERY simple scene. I have an NVIDIA TITAN X card and more than enough memory and other great computer stats to handle anything I throw into DAZ. So how did this happen? I didn't change ANYTHING in my rendering settings! ~_~ I even tried deleting the light set I was using, replacing it and switching to dome only....
  • nemesis10nemesis10 Posts: 3,830
    iray Verbose is a setting mode where the iRay renderer is telling you details about what is going on at each stage of the render; it is not the reason why your renders are taking longer but can often tell you why such as that 3.3 gb geometry consumption...
  • TheKDTheKD Posts: 2,711
    edited May 2017
    Verbose just means it's telling you certain things that are already being printed into the log anyways. I am not sure how lines of text could tax a gpu so much that it would slow down a render.
    Post edited by TheKD on
  • marblemarble Posts: 7,500
    edited May 2017
    Post removed - sorry.
    Post edited by marble on
  • ben98120000ben98120000 Posts: 469
    edited May 2017
    It may be simple scene but something in there haves ridiculous amounts of geometry or behaves like it haves (lots of subd levels and/or displacement subd levels). Recently I coudnt render a simple scene (2 G3F, some primitives for walls and some furniture) because texture memory consumption was over 12 GB. As it turns out 2 bookshelves with around 10 books each consumed 10 GB of memory.
    Post edited by ben98120000 on
  • MattymanxMattymanx Posts: 6,997
    edited May 2017
    I learned from another PA that you should remove all un-needed content from the scene as Iray will still load up textures and meshes that are not visable to the camera.
    3GB of geometry data is a lot.  My Amenazador Version 2 only uses 30MB of vram and its over 400,000 polygons.  With textures its 45MB total
    Post edited by Mattymanx on
