Cannot uninstall DS 4.5.1.6
ruekakaruekaka Posts: 347
Hi everybody!
I try to install DAZ Studio Pro, Version 4.5.1.56, 32Bit on WinXP, but an error occurs while the Setup application tries to uninstall the previous version:
There has been an error.
Error running E:\Programs\DAZ\DAZStudio4/Uninstallers/Remove-DAZStudio4_Win32.exe --mode unattended --unattendedmodeui minimalWithDialogs : Program ended with an error exit code
The application will exit now.
The previous upgrades (to 4.5.0.114 and 4.5.1.6) worked without problems.
If I start the application Remove-DAZStudio4_Win32.exe direct I get an error message that I propably do not have the rights to access the device, directory or file.
- No other application is running
- I download the setup again, same error.
- I restart my PC without network connection and stop my Antivirus (FSecure), same error.
- If FSecure is active I get a message that the application is blocked, but I allowed the execution, but also the same error occurs.
Does anybody seen this before and/or has any idea how to solve this?
Any hint is wellcome.
  • Richard HaseltineRichard Haseltine Posts: 108,934
    Go to c:\Program Files\DAZ 3D\DAZStudio4\Uninstallers and remove Remove-DAZStudio4_Win64.exe and Remove-DAZStudio4_Win64.dat. That should allow the new version to install.
  • ruekakaruekaka Posts: 347
    Thanks for that tip. It worked.
