Ability to leave the male anatomical elements on while wearing clothing
Serene Night
Hi, I would like the ability to keep the male character's gens on when dressed. Kind of a pain to remove them especially if you use a specialty skin with special shaders. But leaving them on can make the pants look funky even if you hide them.
It would save time if there was a way to keep them hidden but still attached so that you don't have to recreate them later.
It would probably require morphs to shrink them significantly smaller than the default size, or a redesign of how they are modeled to accomplish this. I can see what's possible, but I can't promise anything quickly.
is this because removing the geografts changes the UV for the shaders?
Thanks! I admit its just one of those annoyances. I have to save two versions of my characters ones with one without anatomical elements. Yesterday I accidentally saved over the one with anatomical elements and I was so irked with myself.
If I leave the anatomical elements on but hidden the pants just deform in their locale like there is something invisible there.
I think in the ideal world the elements would become a bulge of some sort.
Well, they need dynamics and collision physics to do that well, but I though I read somewhere you have to choose the clothing to layer over other clothing in the correct order for example if you want a shirt to autofit tucked into pants rather than not tucked in you need to have the pants to collide down the shirt and it onto the hips and not the shirt to collide on top on the pants.
Actually it would be very nice for all clothing, hair, muscles, and fat to drape and collide so to fit properly and automatically 'autofit' easy - better than VWD and Optiplex works.
Agreed on them becoming a bulge, to be honest.
If you have some of Sickleyield's Genesis and G2M clothing, some of the pants have morphs in them for that sort of bulge that would go over the elements. I think some of Outoftouch's male clothing may have similar morphs, but I'm less sure about that. Those morphs could be shifted to another piece of clothing with Transfer Utility. Unfortunately, I'm not sure which pants have it, so if you have any of them, you'll need to check.
If you don't have any of her other clothing, Sickleyield also has a pants masculinizer on sale at Rendo. I don't think it's meant to work with the genitals on the figure, though. Haven't tried that; I'll have to see if it works that way.
is it that hard to hit delete and dial in a bulge before render?
the figures should have been anatomically correct to start with TBH then none of these issues
For one image no or course not. If youre doing an image series it can be annoying, having the character set up but needing to remove the geograft to do a render or 5 before you actually need them.
I honestly don't want to remove the elements. I agree it shouldn't be necessary.
I alter the textures of my characters so it's not really a one click process to redo the elements if I should forget and save over them unattached.
I tend to save my characters with all the items they regularly used attached and hidden for ease of use in scenes I might dream up.
I save my characters with everything they need included as well. I also keep backups on an external drive so if I do make a mistake and save over something I shouldn't, I can get it back fairly painlessly. It would be great to have everything attached and fit under the clothes, I agree, and hiding the Element just doesn't work :-( But a backup might save some pain.
How about just hiding it when clothes are on?
You end up with a hole ;-(
I wish it were that simple. But even when hidden the pants form a weird gap where the gens are.
Oh. Poo.
Slightly OT- Believe it or not, Uzilite has some pretty detailed bulges for some of his M3 products. Not the same as having the clothing fit over the gens, but the look is pretty close on a few things. I nearly died laughing when I saw the morph names for his M3 undie set. He has a good sense of humor.
Yeah. LOL There is one Uzilite set that has a really textured anatomical element visible in the pant/groin area. Its basically a very visible anatomical element shadow in the pants. One of my first renders I was so proud of was a character wearing that set. I was ribbed mercilessly by someone online for using that set and that set of pants because it looked far more adult than I had intended. In my defense I had never noticed that, and was really kidn of embarrassed afterwards. I never used the set again!
Ultimately my goal is to choose to bulge or not to bulge. I hate outfits that have a perma-bulge or textured bulge because it makes everyone look the same size and shape. There are a few sets I would use if they didn't have a permanently dialed anatomical element modeled in.
I would like to be able to dial that region or leave it out it out if I so choose.
My workaround is to unfit and hide. This keeps them available in the scene and textured, but eliminates the effect on clothing.
Awesome workaround! Thanks for that tip! I would've never thought of that =-)
Flying unattached invisible anatomical elements... Sounds like a bad film plot device, but hey whatever works.
The ancient Greeks had depictions of flying anatomical elements...
I discovered another workaround on accident--I go neg 100 on default pose, length and width, and leave visible. I don't get that odd cut-off look in pants that way. Might have to remove limits first.
Hmm. I will try that, thanks. I prefer not to unattach them.
Un-hide the PROPERTIES, scale the Astronomical Elephants to 1%, and rehide Properties until needed.
In my case, I use Fit Control in order to adjust the bulge.
Here are a couple of freebie morphs/pose presets I made to shrink the gens so they can be worn under pants, one leaves a small bulge, the other is flatter. I haven't tested them extensively, but they appear to work with most pants.
https://www.dropbox.com/s/wl48gbvdk87hslm/Gens%20Pants%20Morphs.zip?dl=0
Hey, thanks. I'll check this out.
Hmmmmm... what would it take to get a Genesis 3 version of these morphs? And maybe Genesis 2 and Genesis 1 versions? I still usually use G3M for most of my projects, and sometimes G2M.
