Question about my lighting
in New Users
So in this image that is ALL Blue - I am trying to figure out what I am doing wrong.
I have a key and back light as well as ambient light set up. All on white with mid intensity but they aren't showing up at all. Is it because the render environment is all blue and that overrides everything?
3delight or Iray?
IRAY
The blue seems to come from ambient lights on the screens. Are they emissive? Could it be that your lights Lumen is too low or that the room is closed and the lights are outside the walls?
Check your Render Settings > Environment Mode. Is it set to dome? If so, then your manually placed lights will not appear. They only show up if Scene Only or Dome & Scene.
Also, I highly recommend this product. It quickly tells me where all the direct and emissive lights are located in a scene and lets me adjust them: https://www.daz3d.com/iray-light-manager-pro
