mcjKinectKit for Kinect V1 and in June 2018 Kinect V2 - script and exe for DS 3, 4
12346
  • SimonWMSimonWM Posts: 924
    edited May 2015
    I have a question? Do you ever get live recording into DAZ Studio. From your instructions I understood "Write to client" in the server would be used to send a live capture into DAZ Studio viewport via the stick figure.
    I guess what confuses me the most is that the moment I hit record in the client the stick figure in DAZ Studio viewport stops moving
    It still moves in the server window but it stops moving in the DAZ Studio viewport.
    Post edited by SimonWM on
  • mCasualmCasual Posts: 4,607
    yes the stick figure is not ( visibly ) updated during capture
    well it is updated in the timeline's memory
    but the current displayed frame is not changing
    so the image doesn't change
    in an upcoming version there may be an option to keep it moving
    i didn't want to drop capture frames due to intensive CPU use by Daz Studio redrawing the entire image
    the Client just waits for poses to arrive on the communication link and stores them in memory as fast as it can
    so the communication link is ready to receive more poses from the server
    so the server is ready to receive more poses from the kinect drivers
    in my initial tests there even was a live preview directly on a figure
    so those options will be in the next kinect kit update
    but before that i'll roll out the kinect face script
    and before that ( according to plan ) i have to complete 3 or 4 other scripts
    like the midi music app, the pose tools, the poke-through-fix script
    edited May 2015
    TEST 001 Part 2
    the setup
    at that distance the actress is fully in the kinect's field of view
    the kinect can see a large chunk of the floor, so it doesnt have a hard time locating it
    the kinect is level, it's motorized base has 0 degrees of tilt
    the kinect is around 130cm / 50 inches above the floor
    1920 x 1080 - 572K
    1920 x 1080 - 851K
    Post edited by mCasual on
    edited May 2015
    TEST 001 Part 3
    so in part 1 i did a motion capture with the server in standalone mode
    then i loaded a scene containing a Genesis (1?) figure
    i delete any left-over stickman from the scene
    i select Azura (Genesis/Aiko5)
    i start mcjKinectClient
    it builds a stickman
    i click the Client's load mocap button
    i specify i want to load 20150519133454 which was recorded in Part 1
    Azura stands above coordinates [0,0,0] of the Daz World
    we can see the stickman is facing her
    and the stickman stands about 8ft away from her
    because i was about 8 ft away from the kinect, facing the kinect
    i'm not totally sure why my programming leaves stickmen at this altitude (sunk in the Y=0 floor )
    if you select the stickman's root node, you can see there's no keyframes at all on that node
    so we can move him ( the whole animation ! ) to floor level, with just 1 keyframe
    looks like the stickman is only 4 ft tall! i wonder why and if that was intentional
    oops looks like i only recorded 70 frames
    i misinterpreted the server's delay-progress bar
    the delay's countdown starts when the kinect reports the presence of an actor
    during the delay ountdown, the green progress bar, shortens ( like an hourglass of sorts )
    and when the delay is elapsed, the yellow LED goes RED
    and the capture starts
    so i create a new motion capture right now
    1052 x 594 - 212K
    edited May 2015
    TEST 001 Part 4
    now i don't really understand why but this time the stickman appeared at a good altitude
    ( when the pre-capture-delay ended the Kinect had already been tracking me )
    i position and orient Azura's root node where i want her to start Fig 3
    i select Azura
    i start the mcjKinectClient script
    i go in the [ Stickman to figure ] Tab
    as you can see (Fig 4) i wont take the collar feet and hands animations which are usually not very good
    Fig 5 - i do use the "fill missing key-frames button" because i noticed the server did freeze a few times during capture
    ( for perfect capture i'd close Chrome and maybe even pause my antivirus )
    Fig 6 - surprise surprise Azura jumped over there and we'll figure why
    but other than that it's a success!!!
    i mean she does the motions and we'll see it on youtube later !!
    So, as we saw earlier, the captured motion was - an actor standing about 8 ft in front of the Kinect, facing the Kinect
    so Azura is standing 8 ft in front of where she started .... i think that's the (untested) appearances of it all
    1130 x 644 - 306K
    624 x 468 - 99K
    1230 x 752 - 332K
    1112 x 624 - 283K
    1050 x 592 - 254K
    edited May 2015
    TEST 001 Part 5 ( final )
    the first 30 frames at 15 fps
    next which won't be shown here i'll use mostly mcjAutoLimb2014 and mcjKeepOrient to improve the feet
    since our work so far is moderately precious
    we save the scene as moderatelyprecious.duf in case we crash
    Fig 8 - i used mcjDecimate to reduce the number of keyframes to 10 fps
    and i used mcjCycleFilter Synth/Smooth to smoothen the Shin rotations
    note that mcjCycleFilter can also be used to shift the rotation of an entire animation range ( using Synth/Current )
    so if the abdomen is BENDing between -5 and -15 degrees due to a bad kinect camera tilt
    you could bring it back to -10 to +10 degrees using mcjCycleFilter
    important tip about mcjAutoLimb 2014 - set Genesis shin limits to be 0 to 145 degrees instead of -12 to 145 degrees
    this way mcjAutoLimb wont even try those bizarre shin angles which completely messes the work
    also set the limits-Off on the Thighs rotations
    fig 9 fig 10, i anchored the feet using mcjAutoLimb, the anchors were chosen because they were the average positions
    mcjKeepOrient was used to stabilize the feet orientations ( because the legs are constantly moving ! )
    for the record, Aiko5. leg length, foot to thigh is 92.7cm
    script to measure a figure's leg length:
    var skel = Scene.getPrimarySelection();
    if( skel.inherits( "DzBone" ) )
     skel = skel.getSkeleton();
    if( skel.inherits( "DzSkeleton" ) )
     var lShin = skel.findBone( "lShin" );
     var ctl = lShin.getXRotControl();
     var old = ctl.getValue();
     ctl.setValue( 0 );
     processEvents();
     var lThigh   = skel.findBone( "lThigh" );
     var lFoot   = skel.findBone( "lFoot" );
     var len = lFoot.getWSPos().subtract( lThigh.getWSPos() ).length();
     ctl.setValue( old );
     MessageBox.information( "left leg length = " + len, "Info", "&OK;" );
    so right now i'll write a script or use existing ones to correct the hip position so that autolimb can maintain the feet anchors
    1920 x 1080 - 918K
    1280 x 720 - 126K
    1016 x 612 - 141K
    1280 x 720 - 147K
    600 x 400 - 2M
    edited May 2015
    which means i'll soon publish a script ( mcjAutoLimbHelper )
    which helps mcjAutoLimb reach its goals
    by moving the figure's hip just the very precise minimum distance
    so that the feet can reach their anchors ( targets )
    and it will be usable for arms-hands
    if i then smooth the shin animation curves and re-run the mcjAutoLimbHelper script
    i'll effectively smooth the hip position curves
    1280 x 720 - 162K
    1734 x 584 - 411K
    YOUTUBE VIDEO !!!! yay
    https://www.youtube.com/watch?v=UnjaML5B1Yg
    well i was at the encoding stage when i noticed she swings her arms across her chest but it doesn't hurt people in that dimension
    note i use the script mcjSkinLikeThis to give Aiko5 a skin that looks kin'of good in hardware render mode
    1280 x 720 - 371K
    So once you hit record in the client everything happens in memory invisible to the user because there is absolutely no feedback in DAZ Studio.
    I think once you have options to keep the skeleton moving once you hit record in the client it will be more intuitive. Right now one wonders why does the stick figure stops moving. It would be great to have an option to see the actual figure moving in realtime for people with a powerful system.
    edited May 2015
    SimonWM said:
    i'll see
    maybe re-enabling the live mode for stickman will take me only 10 minutes
    if so i'll add a checkbox
    live mode with figures is more complicated ( and will almost surely make you drop frames during capture )
    so that option may come when i resume work on the kinect kit in June or July
    or it will be there today
    but the best captures will always be done with the server running in standalone mode
    i may even add a write-to-RAM mode to the server ... someday :)
    also someday i may make the Kinect plugin for DS3 and DS4 Win-PC 32/64
    Casual said:
    SimonWM said:
    i'll see
    An option for live mode with figures right now would be awesome! You can always turn it off if the system is not strong enough to use it.
    later today, a checkbox in the mcjKinectClient script
    to enable the in-Daz-Studio-scene-stickman animation while recording
    600 x 300 - 994K
    this one was recorded with the DS-stickman-animation-while-recording option
    600 x 337 - 331K
    edited May 2015
    so this evening i'll post a version of the client
    with optional Stickman-animation-during-record session
    and optional Figure -animation-during-record session
    i added reset buttons for the figure and stickman animations
    there will be a setting somewhere to decrease the load that represents the Figure-Animation-during-record task
    instead of attempting to pose-and-redraw the figure at each frame given to us by the Kinect, it will skip a few frames
    ( between 1 and 10 i guess )
    Fig 2, if someday you find yourself wondering why your actor is all shaky jumpy ...
    618 x 502 - 100K
    1170 x 600 - 181K
    edited May 2015
    that's captured in Figure-During-Record mode, not sure why it seems to be in 'seated ' mode
    i vaguely remember that the client's logic is too quick in its judgement about the seated mode
    in an upcoming version the Sever will tell the client if the seated mode is used
    instead of having the client guess it
    dont forget, after using the Figure-During-Record mode
    you need to
    1 - clear the figure animationusing the [ Reset Figure ] button
    2 - use the [ Fill Missing Keyframes ] button
    3 - make sure the transfer range start/enf is what you want ( in the Transfer Tab )
    4 - Use the [ Transfer This Range] button
    480 x 270 - 236K
    edited May 2015
    Well since it's another very Beta version i wont make a big announcement but
    i post it at the bottom of the mcjKinectKit page under the name
    mcjKinectClient_VeryBetaV002.dsa
    it's the DS3/DS4 version but was only tested on DS3 with mixed results
    610 x 493 - 71K
    edited May 2015
    Wow, I tested it and it seems to be getting so close to something easy to use and understand but it is still confusing. When I hit Transfer this range I see the figure moving and previewing the animation. But when I close the server I don't have any animation in the timeline.
    So how it went:
    I was expecting that the "Figure During Record" would mean live capture of data into the Timeline while previewing with the Figure (Genesis etc.) and "Stickman During Record" would mean live capture with the stick figure for less powerful systems.
    None of my assumptions above were correct. So I capture with the "Figure During Record" and the stick figure moves instead of Genesis as I was wrongly expecting. Then I followed the instructions:
    I see Genesis moving now which is EXCITING!!! I close the server, close the client but now when I check the timeline no animation has been recorded. And I'm confused again, back to reading the instructions.
    edited May 2015
    SimonWM said:
    ... instructions.
    normal operation is
    0 - go to timeline frame 0
    1 - select the figure
    2 - start the client
    3 - the client builds a stickman if one is not present in the scene
    4 - if one is present and contains animation from a previous session,
    it's better to clear the stickman animation using the "reset stickman' button
    5 if the figure contains animation it's better to clear it using the "reset figure ' button
    6 - click the client's 'start server button
    7 - click the client's 'record' button
    8 - in the server make sure the "write to client" checkbox is checked
    9 - in the server check-mark the "delayed button
    10 - in the server click the Start button
    11 - go on-stage, wait for the green downcount bar to shrink and the server's LED to turn red, move
    12 - click the server's Stop button
    13 - close the server ( better to close it this way, else the kinect's red/infrared light may stay on - something i may fix someday
    14 - click the Client's Stop button ( this is important )
    15 - if you were using the preview-figure-while-recording option, it's better to now delete the Figure animation using the "reset figure" button, the stickman animation is precious, and should not be deleted now !
    16 - use the "fill missing keyframes" button, the client will finalize the stickman animation by making it 1 keyframe per frame
    17 - use the "Transfer this range" button, the script will transfer the animation from the stickman to the figure ( make sure the Transfer Time range covers the section of the stickman animation of interest
    edited May 2015
    Thank you, with this instructions I was able to capture fine. Some problems though, the figure sometimes drop through the floor, not all times.
    The toes seem to be kept pointing down. Need to adjust the feet/bend option. And this is more my mistake but as you see in my video my timing predictions were too long, I had 2000 frames but I used much less.
    https://www.youtube.com/watch?v=mnyz5k0kTCQ
    Perhaps a frame counter on the server or client would help with not having to guess the capture length. Ideally it would be to have realtime figure capture within DAZ Studio viewport with realtime Timeline feedback. But I'm probably dreaming. Still this is an awesome script as it is, and this new beta is twice more awesome than the previous one!
    edited May 2015
    actually in your video the feet look better than mine, i usually un-checkmark- the feet and hands (sometimes the collars and buttocks ) so they dont get transfered to the figure
    but dont forget to read about the other options in the Transfer tab, because they are related to the floor issues and the feet issues
    note that during the capture, i always have the Main Client tab open, not the transfer tab
    so i can see the "console" messages
    using Daz Studio 3, it takes under a second to build the stickman, with DS4.x it takes many seconds !
  • jaebeajaebea Posts: 456
    I am following this thread with great interest! Would like to know if your plugin will also work with Kinect for Windows?
    edited May 2015
    if it's the first version of the Kinect For Windows ( there's now a version 2 that, i think, it like the XBOX-One Kinect )
    then i think it will work ... but i'm not 100% sure, i did all my tests with an XBOX-360 Kinect
    i was careful to buy one that was sold with the "Kinect adventures" pack, because i read somewhere that they were compatible with Brekel
    then i bought an $8 USB/Power adapter from Amazon
  • TugpsxTugpsx Posts: 811
    Thanks for update.
    edited December 2015
    Back in February 2015 i experimented with facial mocap using the kinect for xbox 360 connected to a PC using a $30 adapter
    and i'm sure 2 or 3 persons in this forum thread will be interested to know that i'm reactivating this project
    i lost the source code of the "server" app and "client" script in recent hard disk(s) failure(s) but it wont be too hard to re-write it
    in fact you can already see i have the head position and orientation covered
    http://mcasual.deviantart.com/art/the-return-of-the-kinect-facial-mocap-for-Daz-Stud-580385623
    the microsoft kinect driver reports on 6 facial features, which they call Animation Units
    to convert this into Daz Studio/Poser face-morph tweakings, i have to write a special mapping system
    the result should make it usable for Aiko3 .... but not only her ! for genesis too, even for cats and dogs
    Here you have Videos ! from Feb. 2015 done using the old Client/Server
    https://www.youtube.com/user/mcasual/search?query=kinect+face
    Always a genius! Looking forward to this Casual, will it work only on Genesis 1 or Genesis 2 & 3 too?
     yes it should work for all figures, the kinect sends us 6 face parameters,
    then there will be a table to map these on the figure
    either i will supply a basic mapping table for genesis 1,2,3 and A3,V3,V4 or i'll let you create it
    it can work on any figure, even a cat ( which i did in my St-Patrick day Green Cat video )
    for now the mapping table looks like this
    for this animation
    var converters = [
    [ AU1_Jaw_Lowerer, "OpenMouth", 2 ], //0
    [ AU5_Outer_Brow_Raiser, "BrowUpR", 3 ], //1
    [ AU5_Outer_Brow_Raiser, "BrowUpL", 3 ], //2
    [ AU4_Lip_Corner_Depressor, "PBMCC_07", -1 ], //3 mcjA3Smile custom smile morph for Aiko3
    [ AU2_Lip_Stretcher, "MouthWide", 1 ], //4
    [ AU3_Brow_Lowerer, "BrowAngleUp", 1 ],
    Great to see this back on track.
    if all goes well, before the weekend ends i'll post a free Kinect V2 bodymocap-to-DazStudio for-PC-only exe and and a Daz Script script
    just like the one i did for the Kinect 360 ....
    in this image you see the kinect-360-stickman which has 20 bones
    the only difference with the kinect one  (V2) seems to be 4 more bones
    maybe maybe, i'll make a live poser-figure mode, using a figure like the SecondLife avatar which is a light CPU load to animate or Victoria3/Michael3/Aiko3
    It's Kinect One (V2) To Daz Studio Weekend ! by mCasual
    V2 meaning it will only work with the new cameras or this is a version 2 of your kinevt script?
    it will be the same thing as the first version - which supports the XBOX 360 kinect
    so 1 executable (.exe) app that talks to the kinect and obtains poses and "prints" them out
    lets call it the kinect server
    and 1 daz studio script that receives those poses and records them while animating a stickman
    lets call it the kinect client
    then in a second operation, after capture is done, converts it into poses applied to a figure
    i dont remember if it was fully compatible with genesis figures
    initially at least, the daz script for V2 wont be compatible with the V1 server
    maybe later
