Twilight hair problem
mikael-aronssonmikael-aronsson Posts: 599
edited April 2017 in Daz Studio Discussion
Anyhone else have problems with Twilight Hair (goldtassel SKU39317) ?
If I put the hair on any G3F character, save it as a scene file and open it again I get the messagebox below and in the log there is:
WARNING: fileinput\dzassetdaz.cpp(5846): Duplicate formula found linking Smoothing Type & CTRLPonyCRight-Left
Support say they could not replicate it so the question is if it's only me (something wrong with my installation) or someone else have the same problem ? the help documentation about "duplicate formula" is old stuff about Genesis starter essentials stuff, nothing about Gensis 3.
1: Yes it is installed correct, no problems with that (DIM)
2: Yes I tried uninstall Twilight and reinstall it again, no difference
Post edited by mikael-aronsson on
  • Richard HaseltineRichard Haseltine Posts: 108,786
    Are you sure there is only the one installation?
  • mikael-aronssonmikael-aronsson Posts: 599
    edited April 2017
    I hope so, it's all from DIM so should be ok, but I will have a look.
    Update: No just one, I do have both Twilight Hair and Twilight Fall, maybe something went bonkers with them, maybe I will try to uninstall both and just install Twilight hair and see if that makes any difference.
  • No, that di not help either.
    1 - the log say it is a warning, will it cause any nasty problems with it there or can I just ignore it ?
    2 - What does it actually mean ( Duplicate formula found linking Smoothing Type & CTRLPonyCRight-Left ) I would assume the settings for each morph is local to that one ?
    302 x 464 - 19K
    It means that there are two instructions to link the two properties. I don't get that on loading - try uninstalling, make sure all files are gone, and then reinstall.
  • SimonJMSimonJM Posts: 6,074
    Just added Twilight hair to a G3F, saved, quit and restarted DS, loaded saved scene and .. no issue.
  • Ok, at least that indicate it's something wrong on my end, that's a start, just have to find out what the problem is, tried uninstall, all files gone and installed again but still same problem, have to dig around a little and see if I can figure where it comes from.
