Hair go crazy
Well, I guess the pictures speaks for itself, when the eyes are made bigger the hair go bonkers around the eyes, look like rubbish, the hair is pushed out as the eyes go bigger, any simple solution to fix this ?
(Mika 7 and Anjou hair)
  • Richard HaseltineRichard Haseltine Posts: 108,982
    That's because the morphs you are using are set to AutoFollow, causing them to be projected into fitted items like the hair. if you select the hair and in the Parameters pane option menu enable Show Hidden Parameters (the lined button in the top corner, or right-click the pane's tab) you can find and zero the auto-generated morph.
  • Thanks.
