How do I export the smoothing level through fbx?
wenquan0821wenquan0821 Posts: 0
edited April 2017 in Daz Studio Discussion
I want to export the model's smoothing level through fbx,Because it supports the expression animation,But the fbx only has a basic smoothing level。
Obj is very friendly to support the export smoothing level,But this does not support facial expressions。
so,How do I export the smoothing level through fbx?Thank you first!
Post edited by Chohole on
  • mikael-aronssonmikael-aronsson Posts: 599
    edited April 2017
    You don't, FBX only export base resolution no matter what you do.
    If you want better resolution mesh animation export you have to use OBJ/MDD or Alembic* export, what software is the target of the export ?.
    * I would stay away from Alembic if possible, it's often terrible, the imported animation is untouchable, often you can't even move the animation to a different position in world space because the Alembic API used leave very little control for the target application.
    Post edited by mikael-aronsson on
