I see Light problem after rendering
Hi
I have a problem.In my other renders where figures are not in the front ,the light in renders looks good but when I render figures in front I don't see any light in render preview and ready png. file.
What should I change or do ?
I will be thankfull for any help.
  • Richard HaseltineRichard Haseltine Posts: 109,488
    I am not sure what you mean - but since you are rendering in Iray you should note that adjsuting intensity on lights is not the best way to go, and that the default environment light will tend to swamp scene lights (or if you have turned the environemt light off then you will probably need to adjust the Tone Mapping settings).
