Daz over Remote Desktop
exstarsisexstarsis Posts: 2,128
Does anybody have any experience with this? I can't run it on my ancient Macbook Air, but I CAN run a rather impressive Remote Desktop session. And as long as I open Daz on my desktop (like it's ever closed... except when I'm using Photoshop+Topaz I guess...) I can use it... mostly.... fine via the Remote Desktop session. But there are quirks. Which I'm investigating! But I was also wondering if anybody else has done this, if there are threads or whatnot. and Forum Search being what it is, I wanted to ask the collective memory while I tracked down a mouse to connect to my Macbook.
  • Yes, this has been tried but unfortunately the Cube View Control (to manipulate the view) nor the Pose Control Sphere works across Remote Desktops due the way in which these controls works (i.e., detects minute shifts in positioning which remote desktop cannot provide).  Otherwise it works... but for me, lack of these controls makes it pretty useless via Remote Desktop.
  • dragotxdragotx Posts: 1,147
    When I've tried opening Daz over an RDP connection (windows to windows) It throws an OpenGL error and just laughs at me.  I haven't seen any workaround for that, but I haven't looked all that hard either since I can't do anything more complex than hitting the render button on a render that's pre-set and ready to go if I leave Daz open before I hit the RDP connection.
  • exstarsisexstarsis Posts: 2,128
    Yup, noticed the camera and pose control stuff. The sliders are also useless, but typing in numbers seems to work. I definitely can't do any detail work but I'm thinking maybe with some camera presets I can do broad scene composition work and test renders.
  • pdspds Posts: 593
    edited April 2017
    I'd tried this a few months back with TeamViewer and ran into all the issues with the viewport manipulation cube etc. I'd read that the problem had to do with latency. More recently, I got a notification saying an updated version of TeamViewer was out and that latency had been reduced significantly. I haven't had a chance to test this claim as it pertains to remotely controlling Daz Studio, but I'm hopeful!
    Post edited by pds on
  • GranvilleGranville Posts: 698
    I have done the sucessfully with gotomypc.com. You have to have an extremely fast connection on both computers. If it starts to lack, I stop using mouse control in the main window and work 100% off the parameters tab. That way I can work even if there is a lag.
  • LlynaraLlynara Posts: 4,772
    I haven't had any trouble using it with Splashtop. I've remoted into it from an iphone on a data connection (external to the network) as well as from work. I didn't like the results remoting in from a Kindle Fire. That was a bit wonky. But no problems otherwise from anywhere. I think it was outpost42 who suggested Splashtop and it works great. It's free to use on an internal network and $16.99 a year to use it on an external network from anywhere. Love it.
  • Kendall SearsKendall Sears Posts: 2,995
    edited April 2017
    There is a startup option to use DS over VNC/RDP, but it is *NOT* conducive to scene creation.  It was added on a request to be able to start rendering processes for animations on remote machines.  You must start DS from the command line and add the "-allowRemote" option to the line.  (or you can modify a shortcut icon)
    Kendall
    Post edited by Kendall Sears on
  • GatorGator Posts: 1,320
    I do, as mentioned you have to start Studio before the RDP connection.
    It's noticeably slower, and detail work is hard.  I only use it to kick off batch renders or renders.  I'm using a gigabit switch.
  • Worlds_EdgeWorlds_Edge Posts: 2,153
    I run Daz on my desktop and wanted to be able to do so from my laptop.  I'm using gotomypc.  It is not ideal for scene or pose set up.  Moving the camera or the character makes the mouse go crazy/makes things move around uncontrollably.  Some days are a little better.  It works fine with parameters dials and such, but I'm not great at using those yet.
    @Llynara - are you saying you are able to remote to your desktop and use Daz via splashtop with no problems setting scenes up?  If so, I may give it a try in lieu of gotomypc.
  • I want to use my Daz Studio in my laptop when travelling. Is there any solution today? Can splashtop work on Daz Studio?
  • kaotkblisskaotkbliss Posts: 2,918
    I use splashtop daily for setting up and rendering Daz scenes :) works a treat, except don't install the monitor mirror driver (which is what most other remote apps use) as that will make the rotation cube and sliders unusable. (If you select the black out remote screen option, it will ask you to install these drivers)
  • AlienRendersAlienRenders Posts: 798
    edited June 2018
    Yeah, the cube controls don't work over remote desktop. I really do wish they would fix the input controls even on desktop.
    As for using OpenGL over remote desktop, I think you need some other tool. But if you start the app before opening remote desktop, it will just send the screen over and will render using the remote hardware. What if you don't have direct access to the remote machine? Well, there is a way to start DAZ Studio so that it uses the remote hardware. You run a script that will disconnect you, wait a few seconds, and then launch DAZ Studio. After a few more seconds, you remote back in and you're good to go. A little annoying, but it works.
    This is the script to run on the remote machine.
    tscon 1 /dest:console
    cd "C:\Program Files\DAZ 3D\DAZStudio4\"
    "C:\Program Files\DAZ 3D\DAZStudio4\DAZStudio.exe"
    Post edited by AlienRenders on
  • talidesadetalidesade Posts: 71
    I have used Splashtop to access my PC from other devices. Its super simple. Splashtop is free if you use it over your home wifi. I like the interface.
    "Fast internet" is not all you need to make it work, though. You need low latency. That is far more important than fast internet. A gigabit connection would be useless if your router has only G band, or you old laptoptop you are streaming to only has G band.
    It is not super necessary, but having an AC band router along with all your devices being AC band, this can give you a nearly latency free connection. That is so fast it will feel like there is no lag. Your actual internet only needs to be fast enough to stream in HD, which isn't really that much. The latency is the primary concern. You can get away with using N band equipment, but you will have a slight lag with the mouse moving a fraction of a second on screen after you move it with your hand. If you can deal with that, cool.
    I have streamed to a loptop and a tablet with Splashtop (it has apps for both Apple and Android.) They work great. There may be some issues with certain sliders or the viewport navigator behaving badly. This depends on your equipment and mouse settings. On the laptop I don't have the issue. On Android I have some issues with sliders acting funky.
    If you are streaming from a PC close by, you might be able to bypass some of those issues by simply using a wireless mouse connected to the source PC.
    Use Google to search the forums, it works well. ATI made a browser script to do that, and you can just search Daz from Google itself.
  • hyteckithyteckit Posts: 167
    I successfully used MS Remote Desktop on my Mac and was able to connect to my Windows 10 Pro machine that is running DAZ. No OpenGL errors. Had issues with OpenGL when the PC is running something else besides Windows 10 Pro.
  • iSeeThisiSeeThis Posts: 559
    edited July 2018
    I suggest everyone pay attention to Kendall Sears. I've tried it and it works like a charm! Just create a shortcut to open DAZ (in case you, like me, deleted it) and add -allowRemote to the Start line. Thank you Sears. I don't know why no one in this thread tried it. I almost download Splashtop but happened to see your comment. (the OpenGL message comes as usual but DAZ itself runs perfectly!)
    BTW, I compose and edit with my DAZ for Mac. I use Google Drive as document center. The dial is useless anyway even with -allowRemote. But that's fine for me because I don't have to spare a monitor to open DAZ any more!
    Post edited by iSeeThis on
  • JazzyBearJazzyBear Posts: 805
    A little trick for ALL LOCAL versions of Any remote to ELIMINATE Mouse Lag (and to allow the Cube to work) is to use a Wireless Mouse from the SERVING computer and take it with you into the VIEWING Room. Obviously YMMV on distance with a wireless but a bluetooth mouse can go quite far.
    Yeah, it works but somewhat interface delay occurs.
    Okay, thanks to all who recommend Splashtop. I gave it a shot and never regret till I die. I just realize that it's really free for personal version and that's all we need to run DAZ locally. Thanks all of you and thank to myself coming to this thread!
  • CGI3DMCGI3DM Posts: 279
    edited July 2018
    Remote operation
    • All clients tested have been significantly improved
    • Responsiveness depends heavily on the frequency of mouse events
      • RDP has performed the best in internal testing
    https://www.daz3d.com/forums/discussion/265581/daz-studio-pro-beta-version-4-11-0-171
    For 4.11.0.171, work fine for Anydesk, Remote Desktop, TeamViewer, SplashTop.
    Post edited by CGI3DM on
    CGI3DM said:
    Remote operation
    Is it really okay with you? For me the dial button is still useless anyway.
    Rob says
    Synergy (v1) also "works"... although it has a "fly-by-wire" feel to it (as opposed to mechanical flight controls) due to lag; which ultimately reduces the frequency of mouse events and therefore causes it to be less responsive than direct control.
  • Batch method works completely.
    This is the original forum post for the solution if you want to take a look at:
    https://social.technet.microsoft.com/Forums/windowsserver/en-US/c8295ef8-3711-4576-9293-2c4965280165/opengl-and-remote-desktop?forum=winserverTS
    Just open text editor and paste the code below. Then save as .bat file, then click on it. What it does 1- It temporarily disconnects you from remote desktop 2-Open Daz3d.
    Since you're not connected through rdp, daz studio utilize your gpu as its main open gl processor when opens; instead of the crappy simulated rdp opengl engine (which is open gl 1.1)
    All you need is to reconnect after few seconds. It works!
    @echo off
    echo.
    echo Remote Desktop will be temporarily disconnected . . . please reconnect after a few seconds.
    echo.
    pause
    @echo on
    REM The active session has an arrow as the first character
    setlocal EnableDelayedExpansion
    FOR /F %%A in ('qwinsta') do (
        set tempSessionName=%%A
        if "!tempSessionName:~0,1!"==">"  (
            @echo on
            tscon.exe !tempSessionName:~1! /v /dest:console
            @echo off
    @echo off
    echo.
    echo Starting MyProgram.exe . . .
    @echo on
    cd c:/Program Files/Daz 3d/Dazstudio4/
    start Dazstudio.exe
    @echo off
    echo.
    pause
