Strange effects on gloves after converting from V3 to Genesis3
I fitted the old "Scorpio Rising" from AlfaSeed (for the Victoria 3 figure) to Genesis 3 via the new autofit program. When moving the fingers there are strange "gum"like streaks from the fingers. This happens only with the fingers, when moving other parts of the figure all works correct. When i fit the gloves to the original V3 figure all works fine.
I also tried other gloves for V3 on Genesis 3 but all worked correctly.
What could be wrong?
  • Richard HaseltineRichard Haseltine Posts: 108,454
    The weight-projection has assigned areas of one finger weights from the other finger, or has simply missed areas so that they have no weight for the fingers at all. The former leads to bits movingg with the wrong finger, the latter to bits not moving at all.
  • chrbou2001chrbou2001 Posts: 120
    Ok, you describe the problem very well. Is there a way to change this?
    The fix would be to edit the weight maps, using the Node weight paintbrush tool and perhaps the Geometry Editor tool for selection/hiding parts of the mesh
