Warrior Wet Hair and head morph problems
freni-kynfreni-kyn Posts: 394
edited April 2017 in The Commons
I'm having an issue with warrior wet hair.  In general I love it but I can not get it to cover the scalp enough.  I think maybe this was done on purpose to emulate an older man however it looks almost like the hair is coming out of the forehead of the genesis 3 male, and it is coming out of the forehead of the genesis 2 male.  I've searched for a cap in all the files and can't find one.  I also went through both the smart content clickables, as well as went through all the options in the paramaters tab and the shaping tab.  While there is a button to show more roots it did not seem to do much, especially on the genesis 2 guy.  If needed I'll fix it in photoshop but I'm hoping someone can tell me what to do.  I've even cinsidered loading an extra one, unparenting it and hiding almost all the layers then just placing a piece on the forehead.  I also tried to find a way to make Gabriels head smaller but that was a total fail.  i honestly thought I had every head morph availaible for genesis 2 males.  Is there no way to reduce the height  of a forehead?
Post edited by freni-kyn on
    edited April 2017
    yeah, that doesn't look good. This illustrates a big issue I have with hair for men currently on the market.
    At any rate, if there is no cap included, try using a cap from another hairstyle with the same colored hair.
    You might also try NDC Nadino's Forehead Minimizer in the freebie section  to see if you can tug that scalp down some.
  • freni-kynfreni-kyn Posts: 394
    I assume you mean in the freebie section of the store?  I also have a major issue with the men's hair on the market.  This one actually looks better than most as far as styling goes.  But, unfortunatly, it's not working well in the front.  I understand that for the g2m, since it's not made for it but not crazy about the effect on the g3m either.  I've bought and discarded so many of them as unusable for men.  Way too fluffy and puffy.  I have even rendered hair with the skin blacked out just so I could cut out the hair and fix it in photoshop to a more realistic style.  I tried just using a piece of the hair, unparented, but then the 'cap' that is invisible actually shows up as a dark mark on the forehead so I had to parent in place and fit it back to him again.  Kind of a pain but it helped.  I think this one is going to be a photoshop fix.  Thanks for the cap advice and I'll look into that forehead minimizer.  Gabriel model has a oddly large forehead for a teen.
    This worked like a charm.  I had to google to find but so glad I did.  Thank you.
