ancient egypt exhibit
mcorrmcorr Posts: 1,104
edited April 2017 in The Commons
does this include the OBJECTS in the cases, the mummy and the busts, ... or only the room, the reliefs on the walls and the empty cases?
Post edited by mcorr on
  • Charlie JudgeCharlie Judge Posts: 13,400
    There are seperate props. The display cases include the object as a single prop of both case and object
  • mcorrmcorr Posts: 1,104
    I see. Are the mummy, the large back bust, and the wall reliefs also included (in other words, everything on the promos)?
    Everything is included in the set but some things like the wall reliefs are built into the set and not seperate. The attached screen shots show what is seperate.
    328 x 580 - 57K
    299 x 339 - 29K
    tremendously helpful ... thank you soooo much!
