problems with tile and offset
edited January 2013 in Daz Studio Discussion
Hello,
I have a problem with the tile and offset setting for textures in Version 4.5.
It looks alright in the posing and shaping window, but after rendering it is not like I have set it.
I have the pictures in the attachment - I hope;-)
Post edited by Immersive-DreamWorld on
  • KhoryKhory Posts: 3,854
    Which base shader did you use? Daz default or ubersurface or something else? It is likely that the preview is not showing the tiling and offset.
  • wancowwancow Posts: 2,708
    Yah... test tiling using DAZ Default Shader, then switch to UberSurface if that's what you use... :)
  • barbultbarbult Posts: 26,543
    There is a known tiling preview bug. You can read about it here if you have a Mantis account. https://bugs.daz3d.com/view.php?id=48663
    It has reportedly been fixed in version 4.5.1.59 (which hasn't been released yet).
  • edited January 2013
    thank you very much.
    Yes I used the default shader from DAZ Studio.
    I can try to use UberSurface shader but if it is a bug I hope it is fixed in the coming vesion:-)
    No I do not have a Mantis acc.
    EDIT:
    So now, I have created an account for Mantis and went to the link.
    I did what they wrote there (use an integer) and now it worked:-)
    So thanks again!
    Great! I'm glad it helped you find a workaround that resolved your problem. With a fix version number so close to the current version, it will probably be in the next release.
  • MarshianMarshian Posts: 1,465
    Hi Hey Howdy-
    I've never had to adjust this before but I'm working with a model that has some unique ways of lining up textures- Is there a way to control tiling offset with Ubersurface? I need the qualities of Ubersurface but it's restricted to Map Tiling U & V.
    If not - Is there a way to control placement and alignment of the UVs by using the polygon editor?
