'Suite 2101' product - Can't get the lighting working
wintoons
Hi guys, I need some help.
I bought the 3d enviroment 'Suite 2101' and it has the option to add day and night HDRI lighting surrounding in the scene.
https://www.daz3d.com/suite-2101
But the problem is the lighting is not working and the scene becomes completly dark when rendering.
And when I delete the lighting off the scene having no lights add all, I can see the model.
Can some one please give me a few pointers as to how to add the lighting HDRI options for the scene?
Ok I've figured it out, it only works in 3delight. Is the uberEnviroment 2 light only works with 3Delight instead of iray?
Yes, uberEnvironment is for 3delight. You should be able to apply the map it uses to the Environment Map in Render Settings for Iray use.
Here is a iray preset for the scene: http://www.sharecg.com/v/80092/browse/21/DAZ-Studio/Iray-preset-for-Suite-2101
You should be able add the HDRI to this.
Thank you so much!
