G3F UV map for G1 ?
TaozTaoz Posts: 10,299
Any G3F UV maps for G1 out there?
  • Richard HaseltineRichard Haseltine Posts: 109,465
    Not that I am aware of - remember it is more than just a UV map that is needed.
  • TaozTaoz Posts: 10,299
    OK, not sure what is needed, but is it different than with G3F > G2F (which is available)?
  • HavosHavos Posts: 5,629
    Technically it could be done using a system similar to the G3F > G2F product (ie by Caymen Studio's), however anyone doing this would have to consider that there would be sufficent demand for the product to justify the time spent to do it.
    The principle would be the same, but it would need new GeoGrafts for the figure
  • exstarsisexstarsis Posts: 2,128
    I've always wondered how that would work. I thought GX toG3 worked because G3 has fewer polys. I know the Cayman g2 product adds stuff. But would something for the older models also have to add stuff?
    OK. Yes I was also looking for one in Cayman's store, but I guess there may not be enough demand for one.
    Thanks!
    The problem, in either direction, is that the surface boundaries don't match at all in certain areas.
