Adding to Cart…
yea I guess we do get carrie away sometimes. Sorry SY
Water should be a gas at room temperature – all similar molecules, such as hydrogen sulphide (H2S) and ammonia (NH3), are gases. The stickiness of water molecules holds them together as a liquid.
Which is why the oceans don't freeze over (ice is less dense than liquid! That's WEIRD), and water is a powerful solvent, and all that is key to life on Earth.
Well, most oceans, most of the time, Will.
Ugh, I messed that up. I meant froze SOLID. Which actually has happened at least once very early on, probably.
You can freeze some of the oceans all the time, and you can freeze all the oceans some of the time, but you can't freeze all the oceans all the time.
I think chatter about Fast Fog and Fast Flames was more on topic than all this water chit-chat
Splash Pack Iray! hurray!
be great to have splashes/ripples that work with g3f/g3m figure cross-sections...circular forms just don't quite do it.
j
j
I did end up getting it even with my slow CPU computer and rendering a character with a martini now and it looks great! Rendering faster than the character and already looking good. But now I need olives!
nvrmind. After wiping all files from all folders and reinstalling it worked ok. Only files it wanted to overwrite were some .dsa files or .dsx files, forget which.
I'm confused, too, then. Rigged Water Iray 2 uses updated techniques and methods and completely new content. It doesn't use ANY of the textures or mesh assets from Rigged Water Iray 1.
It sounds like you already had Version 1 installed somewhere and over-wrote it on reinstall? The library folders from the product are in Props and are called "Rigged Water Iray" and "SY Rigged Water Iray 2."
Sure you can! You can a.) Switch off or completely block the sun, B.) knock the Earth out of it's orbit, C.) install really heavy duty refrigeration units in all the oceans, or D.) have everyone on earth start making ice in their fridges as fast as they can, then dump it all into the ocean. Okay, none of those is really likely to happen anytime soon, but anythning's that's not 100% impossible is technically still possible. :)
