Bounding Box go away! Shooo How?
Griffin AvidGriffin Avid Posts: 3,824
Issue is the bounding Box. I want to edit small details like eyes and such and teh box appears and covers the item I want to edit.
Click away and I lose the selection in the scene tab.
I tried to edit the size and opacity (see image) but that does nothing,
How do I get rid of the little white box and it's frame helpers while I still have an item selected?
Post edited by Griffin Avid on
  • Richard HaseltineRichard Haseltine Posts: 108,764
    That's not the bounding box, that's the tool widget. If you are editing using the sldiers then try switching to the node selection tool, or even one of the non-node tools if you make your selections in the Scene pane.
  • Griffin AvidGriffin Avid Posts: 3,824
    Thank you Sir!
  • ToborTobor Posts: 2,300
    Maybe I was dreaming it, but I could have sworn there was a way to do this with the Universal tool. No?
    While on the subject, I guess D|S doesn't have the unmirrored scale control like Hexagon does -- many times I'd like to scale from one side only. Or maybe there's a setting buried somewhere? If anyone knows about where to find it, it's you, Richard!
    I don't think you can set an action centre, other than by adjusting the centre point or using a DForm.
