Jenn HD Trish HD
13»
  • ArtiniArtini Posts: 10,360
    Hi, Kayleyss. Is it possible to have both looks available after update, the old one and the new as a separate settings?
    If you copied the current morphs into a separate content folder and renamed them, you could preserve the existing dials.
    Yes, that can be an option. May be if I can save it as a material preset, but I do not know if it preserves all of the maps.
  • kayleysskayleyss Posts: 90
    Hi,
    I will see what I can do to keep 2 separate head shapes.
    I'll be back smiley
  • jardinejardine Posts: 1,217
    many thanks, kayleyss!
    j
    edited March 2017
    I create a preset to smooth lower lip for Jenn and Trish. Here is how it works:
    This preset change the Normal Map and ADD a morph that smooth the lower lip. It has to be apply after setting makeups because, if you apply makeup after the smooth preset, the old Normal Map will comeback.
    So there will both the old morph by default, and possibility to smooth lower lip smiley
    Here attached Trish and Jenn with and without smooth
    1559 x 1186 - 446K
    1559 x 1186 - 445K
    1559 x 1186 - 440K
    1559 x 1186 - 440K
    Post edited by kayleyss on
    Beautiful. Thanks kayleyss :). For my part, I had no problem with the original lips, but it's nice you listen so well to your customers :D
    Laurie
  • 3Diva3Diva Posts: 11,981
    kayleyss said:
    With normal maps smiley
    Looks great!
    This preset change the Normal Map and ADD a morph that smooth the lower lip. It has to be apply after put makeups because if you apply makeup afte the smooth preset the old Normal Map will comeback.
    Awesome! That looks really good! Thank you, Kayleyss!
  • NovicaNovica Posts: 23,925
    I will be sure and post on my Art Studio thread too that new maps were provided in case anyone wanted those. Thanks so much!
    Thanks
    I have submit the corrections. When they will be online, I post a note here.
    PS: just one thing, I am a man ;)
  • glaseyeglaseye Posts: 1,312
    edited March 2017
    Thank you in advance, although I haven't noticed any of the mentioned problems yet (probably because I had no need for that high level of subd....)
    Just another tryout with your Witcher characters (still a little too much noise in the image, but that's because of my choosen method of lighting...); I don't recall I ever used any character(s) as much in renders as I've done with these.......
    Post edited by Chohole on
    LOL, we fixed that hours ago, a few minutes after the post. My avatar's a horse, so folks didn't know what I was for awhile either LOL.
  • marblemarble Posts: 7,500
    You mean you're NOT a horse!?
    Hsssssssssssssssssssssss... BOOM!
    Hehe! it's ok :) Like you say it's hard to know how's behind the avatar :)
    Hand over the carrots and nobody gets hurt!
    edited March 2017
    Thanks a lot, kayleyss. There will be great to have such an update.
    Post edited by Artini on
  • nicsttnicstt Posts: 11,715
    edited March 2017
    marble said:
    marble said:
    Yes, I have GIMP. I didn't know that it can edit Normal Maps though. I know that Photoshop has a plugin available from NVidia for creating Normal Maps but I didn't think that worked with GIMP.
    I just take the TIF file and edit it directly. I'm not generating a new Normal, I'm just editing.
    Interesting - I didn't know that was possible. I don't really understand NMs so I thought they had to be recreated from greyscale maps or from HD type 3D object surfaces.
    They are just image maps; although data can be destroyed when editting, what I am mainly doing is copying data from elsewhere; I save it as a new normal map so the original is still intact and test it out.
    Use the clone brush; one thing i do most is get rid of eyebrows on normal maps as I'm using figremesh ones (yes I have Zev0's brow remover and use it). I have had success at correcting issues on seems, but that is more hit and miss.
    ... And sometimes, it just doesn't seem to work as well, and no clue why, but when that happens I live with it, or use the originals.
    Post edited by nicstt on
    Hi everyone!
    The update for Jenn and Trish should be online now smiley
    854 x 450 - 125K
  • Great! Buttons to swap the Normal maps.
    1800 x 1417 - 644K
  • I thought it would be interesting to note that there is a big difference (about the size of that line) in the lip UVs for V7 and G3F. The Blue UV is for V7, Pink UV is G3. The transparent lips on top is from the makeup resource listed on both the Trish and Jenn readme pages. AND, if one is also creating a custom morph, those merchant resources could be chaos for any character. One could possibly have layers on top of layers of different peoples textures (some for V7, some for G3), saturation levels, tone levels etc. I may be way out in left field, but just an interesting note. :)
    1317 x 886 - 554K
  • ChadCryptoChadCrypto Posts: 596
    These are awesome characters! Good work Kayleyss. I picked up both of them. One in each arm :)
    Hehe, it not only swap the Normal Maps; it also add a HD morph that smooth the bottom lip smiley
    Hi
    Yes, Victoria 7 and Gemesis 3 female have diferent UVs (like most of the other Daz iconics figures). Trish and Jenn use Genesis 3 female resources, and they also use genesis 3 female UV. The reason they is "...for Victoria 7" in their title is because they use Victoria's morph ( body at 100% and head at 15%) smiley
    This line was an artistic choise. But, it appear that it was not to the taste of everyone. That's why I decide to create this smooth preset to lower the effect smiley
  • cismiccismic Posts: 629
    Taozen said:
    scorpio said:
    I have one of Kayleyss's other characters Gwennili and she's amazingly detailed and by far my favorite character - so I wouldn't worry about the darkness "hiding" anything, as, from what I've seen with Gwennili, that PA does amazing work and doesn't try to get away with hiding any defaults or anything like that. From my experience, the PA does work of the highest caliber.
    Yes I agree I have Gwenbleiz - awesome work, I just find the promos tend to make me slide past the character hard to explain exactly what it is.
    Same here - I don't even recall having seen these characters at all, despite I check the new items in the store every day. I do have her Tara&Sachra and Gwennili characters though and they look great though maybe a bit ordinary (well not Sachra I admit lol).
    I'm planning on getting https://www.daz3d.com/gwenbleiz-hd-and-beard-for-michael-7 today.  Glad I decided to search the forums first. I've not thought about https://www.daz3d.com/gwennili-hd-for-victoria-7 until now. She seems hardend and will work in a lot of varying renders.
    Joseph
