Genesis 3 Male pelvis bend frozen?
Tako Yakida
I haven't updated G3M in a while so maybe I just need to do that, but my G3M's pelvis bend slider is pinned at 0 by default. Is there a way to change this default?
There is a chain symbol next to it which I can click to make it move but I have to do that each time I load in a G3M.
If the link is what is stopping it (clicking the chain icon so it breaks turns off any ERC links to other properties) then the problem is probably that your bend is being multiplied by another property that is currently 0. If you click the gar icon on the right-hand end of the slider, then Parameter Settings, and look at the Controllers tab that should tell you which properties are affecting the bend and help you to identify the culprit.
Thank you Richard. I believe I found the culprit which appeared after a recent install of something. I should probably report it as a bug.
