Can Not delete properties from prop
ScavengerScavenger Posts: 2,674
I have an object that I carved out of bigger object.
The bigger object had various controls that have nothing to do with the smaller one.
I have tried to delete the controls, then save as a prop asset....but when I reload, they come back.
How do I do this?
  • Richard HaseltineRichard Haseltine Posts: 109,399
    You may need to go to the Data folder for your item and delete the property .dsf files (from \Data\YOU\Product\Moprhs\You\Morph set, where the folder names will match the author and product fields from saving).
  • ScavengerScavenger Posts: 2,674
    That worked! Weirdly, the other stuff I did similarly didn't need me to go into the file system...but one did.
