victoria 5 not working for me.
club3000studiosclub3000studios Posts: 0
ok so when i try to open vic 5 in daz, all it says is that i dont have some files that i need, these are the files it says i need,
/data/DAZ 3D/Genesis/Base/UV Sets/DAZ 3D/GenePool/Victoria 5.dsf
/data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 5/FBMVictoria5.dsf
if someone could walk me through how to get this working i will forever be in your debt :)
    Sounds like it didn't install correctly. Double check your installation directory.
    What version of DAZ Studio are you using? Help > About DAZ Studio
    You MUST install V5 into the same location as Genesis, since V5 is a morph of Genesis and requires that base to work. Where are you loading V5 from? I load it from the Parameters pane, Actor > Female > Real World > Victoria 5, and push the slider across to the right, until it is set to 1.0
  • Richard HaseltineRichard Haseltine Posts: 108,433
    Actually the morphs will be found if they are in a different DAZ Studio content directory, at least in any version of DS newer than V5. However you do have to install to the actual content directory (My Library or whatever), not to a subfolder of it.
    Richard,,, waht you mean "actual content directory"?:ohh:
    when install character morphs from daz shop by instaler , we need to locate the daz contents folda.
    then they install morphs into sub folda (in data ) of daz contents folda.as you know.
    so , if I make new daz contents directory for genesis character morphs,
    eg I:/new/ genlibrary , then when install genesis characters by daz installer,
    I just locate " I:/new/ genlibrary " as daz content directory, it work too?
    (may need to tell cms, " I:/new/ genlibrary " as new daz content directory )
    or I must install "morph.dsf" under genlibrary folda manually?
    so i can not make any sub folda in genlibary? it means i can not use installer.
    or you said, I need to keep "same directories strucutre " as same as "geensis content directory" where installed genesis,
    eg ,,, I need to make sub foldas for the new genlibary,,
    genlibrary/data/DAZ 3D/Genesis/Base/Morphs/vendor name/product name/morph dsf?
    The folder installed to has to be one that appears under DAZ Studio Formats in the Content Library pane, and not a folder inside a folder that appears there. Ds will check all the \Data\DAZ3D\Genesis\Base\Morphs folders when loading Genesis.
    I understand. thank you ^^
    I may just need to set the new directory as DAZ Studio Formats content diercotry in content library,
    (not sub directory of other daz content directories )
    then when install products , select the new content directory (if i hope to install them on new content directory).
    (I believe it must work when I save morphs for genesis in ds 4.5. just point another daz content directory,
    ds may saved the dsf, in morph folda under the data of new content directory,, ,,)
    So that, in ds 4.5 we need not to install morphs or new UVset s for genesis on same content directories any more,,
    DAZ may need to correct the documents about genesis character morphs in shop I think. :coolsmile:
  • i get told the same thing but mine tells me this should i just remove this file ??
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseSeptumDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawCurve.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMCollarboneDetail.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMGlutesWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseRidgeWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMMouthCurves.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNostrilsFleshSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceYoung.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawCornerWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsHeavy.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesAlmondOuter.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesPuffyUpper.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMThighsTone.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMCalvesFlex.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsBottomInHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesAlmondInner.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/SCLChestWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyeIrisSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMHipBoneCrest.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsImplants.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMJawAngle.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeSlope.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMAreolaePerk.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBump.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMLineaAlbaDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesHeightInner.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseSeptumHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelashesCurl.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseTipHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMGlutesUpperDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelashesLength.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsBottomOutHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMMouthDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEarSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseTipWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMPupilDialate.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesHeightOuter.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMBreastsNatural.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelashesHideLayer.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMFaceRound.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMStomachLowerDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNosePinch.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseBridgeWidth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/FBMBodyTone.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyesSize.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMStomachDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyelidsTopInHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNostrilsHeight.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PBMNipples.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMEyeIrisCorrection.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMNoseTipDepth.dsf
    /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Evolution/PHMLipTopPeak.dsf
  • fixmypcmikefixmypcmike Posts: 19,696
    Are you getting the message that those files aren't being found?
  • Yeah that is what it tells me when I try and load the Vic 5 Gabi
    Do you have the Evolution Head and Body Morphs, that is what DS is looking for?
