Dynamic sheet is too wrinkled
I have the dynamic plugin and the dynamic sheet. I want it to just cover a bed, but I cannot get out the wrinkles or have the sides go dow at 90 degree angles from the top of the bed. I could probably do it in Poser's cloth room, but I want to do it in DAZ studio 8.xx. Can someone share settings for this that might work. I have tried numerous settings and can't get the look I want. Thank you. (In the line above, the word"dow" should read "down".)
  • ingoingo Posts: 52
    can you post an image of how it looks at present?
    to get the wrinkles out make the fabric more stiff. reduce the stretch and increase gravity (2x -4x) to pull down the sides. you also can increase the weight of the fabric.
  • I have tried many combinations. Here is the least creased. I wonder if it is the settings or the dynamic sheet itself. I don't know enough about dynamic clothes to guess.
    275 x 231 - 7K
    That looks like the cloth might be sliding in towards the middle from the ends. Try turning the friction setting up and the Bend Resistance down.
  • I have tried so many combinations without much difference. Could it be the sheet and how it is constructed?
  • Oso3DOso3D Posts: 15,095
    You could try a smoothing modifier?
  • Richard HaseltineRichard Haseltine Posts: 108,967
    OptiTex clothing can't be smoothed unless you convert it to a static prop first - same for DForming it.
    Then copy it (so you don't lose your place), convert a copy to static, subdivide/smooth. That's what I usually do with all dynamic stuff.
  • Thank you. I will try these last few steps mentioned.
  • Thank you again. It worked perfectly, better than I would have thought.
