Daz studio bone rigging
How to fix this problem. I dont know how to rotate bones.
  • Richard HaseltineRichard Haseltine Posts: 109,160
    How did you create the skeleton? Is the OBJ grouped? Any way, use the Joint Editor tool to move the centre and endpoint, then right-click and align the bones to snap them into place. The right-click menu also has an option to snap the origin of the bone to the end point of its parent, which can simplify matters.
  • edited January 2013
    I used transfer utility. I dont know what OBJ grouped is. Snap utility always transfer the one which i dont wana move
    Post edited by witcherask_a3dd58a1c6 on
    A grouped OBJ is exactly as it sounds, a Wavefront OBJ imported model which is separated into individual pieces grouped together to make a whole. Adding a skeleton to a single unified mesh tends to be a bit easier.
  • edited December 1969
    Yes its grouped. Is there any easier way to align bones. Currently when i align one other gets messedup and so on.
  • BejaymacBejaymac Posts: 1,965
    Time to go read up on how to rig a custom figure, as borrowing the rig from another figure wont help you any, especially when they have such different default "T" poses.
    Any link to tutorials might help
    There is this link to a store item, and it is excellent for what you want.
    http://www.daz3d.com/rigging-original-figures-in-ds4-pro
    No paid tutorials
  • wancowwancow Posts: 2,708
    Goto Tools: Joint Editor. Right click under one of the tabs and add your tool settings. Select a bone and you will see the numerical values for the center and end points, and the offset value.
    If you select a bone, you can also use the arrows to move the center and end point manually.
    Thx for that information. When i move a bone there seems to be two bones one with red and one with grey which gets confusing . Anyway to get rid of grey bec i cant seem to select it and dont know what purpose it is for
    use the Scene tab to select bones if it gets confusing or difficult to select bones.
