Question on Brick Collection Merchant Resource - Vol4 (PBR Textures)
Could this item be used to simply add textures to an item I already have?
Could it be applied as a texture to an item in the viewpane for rendering also?
Thanks. I am very uninformed about this kind of thing.
R
    edited March 2017
    Yep, you'll just need to set the materials up yourself as there are no *.duf files. If you're using iRay, depending on whether youre using spec/gloss or metal/rough, you wont need all the maps.
    Post edited by Lissa_xyz on
  • IceDragonArtIceDragonArt Posts: 12,844
    To expand on that for those not super familiar, you will need to load these manually into the surfaces/diffuse tab for them to apply to your model in Daz Studio.  So you would click on the little square to the left of color bar in the diffuse tab (under surfaces) and click on browse, then go to wherever you loaded the files (I load mine into a pictures folder titled textures just so they are easy to find) and click on the one you want to apply.
    These are gorgeous textures and well worth the extra small steps if you want to use them inside Daz Studio.
