Clothing Rigging Issue
Okay. I've been working on this outfit for DAZ3D and Poser. I've managed to get everything modeled. I worked around issues of rigidity, coloring, texturing, and more. And I'm so close to completion that I can taste it. And now...I've wound up with another problem. >:[
I've used DAZ3D's transfer utility to rig and weight map everything. And for the most part, it worked out perfectly. Except for one serious glitch.
There's a problem in the crotch area that shows up whenever I most the thighs. I'm including imagery of the affected area; an image of how it looks in the default pose, an image of the transfer utility settings I'm using, and one of the distortion that I'm getting. So if anybody can offer any suggestions on what I can do about this mess, I'd really appreciate it.
(Also, I hope me showing images focusing on the crotch area doesn't qualify as obscene content. This is just where I'm having the problem and nothing I do seems to help.) :(
  • Richard HaseltineRichard Haseltine Posts: 109,475
    It looks as if you need to edit the weight maps to smooth the effect out - that area is very hard to get right as there are several bones close together.
  • OrionPax09OrionPax09 Posts: 419
    I actually managed a...well, partial solution by fiddling with the Near Vertices and Adaptive Tolerance slides. It's not perfect, but it's a lot better now. Enough so that I'm not willing to go out of my way to tear my hair out even more over the matter.
