Question about iSourceTextures products
dragotx
Are these Iray compatible textures? I'm not seeing Iray mentioned anywhere in the description.
dragotx
They work fine in iray. Once you have a surface you like you can then save it as a shader in My Library.
Awesome, thanks!
These ones don't come already set up as shaders. They are just texture images, but as long as you're comfortable with plugging in the diffuse, normal and tile settings in the surfaces tab, they can definitely be used.
Reading through the what's included on these, it seems you may have to do some fiddling yourself. There's a mish mosh of textures for both spec/gloss and metal/rough workflows; however, there are gloss maps, but no spec maps, roughness maps, but no metalness maps. The easiest is to use the metal/rough workflow and set the metalness colour to black, since none of these textures contain any metallic surfaces.
Anyone know where isource get the Daisy Dukes from here: https://www.daz3d.com/anzhelika-hd-for-genesis-8-female?
Answered elsewhwere - please don't double post.
https://www.daz3d.com/forums/discussion/295216/anzhelika-hd-for-genesis-8-female-dukes#latest
