March Madness?
March madness has lost it's apeal since the passing of Carrara
  • RealtimeRealtime Posts: 95
    I just reloaded Carrara in Mac 10.11.6 and see nothing...
    I guess this should motivate me to move toward Daz studio. NO!
    I am officially leaving after almost a decade.
    I'm going to blender where the community actually matters. This is sad, because I really loved Carrara. I can only take so much negligence..
    Daz...I really wish the rest of the community would tell you...what you should know...you suck. You should have treated us with some respect.
    Amazing that Daz studio works!!!
    guess what? I will never use Daz Studio! Why?
    because of how you treated the Carrara Community!!
    edited March 2017
    Seriously - I wish you Daz would have never have purchased Carrara...
    Post edited by Realtime on
  • StezzaStezza Posts: 8,894
    I've gotted some cool mad stuff to use in Carrara... for me anyways yes
    Seriusly...this is all that loads.
    Anyone else have this issue??
    1337 x 813 - 115K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,559
    are you opening the rendernode?
    also there was an issue some had on Windows 10 needing running in compatibility mode
    maybe the Apple users can help out.... at least the screen shot looks like it's on a Mac... sad
  • GreybroGreybro Posts: 2,614
    Realtime, take a breath Bro. You just don't have the content installed.
    Content ha been installed with the install manager. So who knows!
    Let me install this real quick and see what my experience is.
    I am installing the following for my test.
    Carra 8.5 Pro (Win 64 bit)
    Carra 8.5 Pro Native Content
    Carra RenderNode 8.5 (Win 64 bit)
    Does this line up with the peices you installed?
    edited March 2017
    Well Sir,
    I got the same very poor experience on loading Carrara 8.5 Pro the first time. I suspect that the 8.5 Pro Native Content doesn't provide all that much and you need to install the 8.0 Native Content. Going to sort this shortly.
    1920 x 1032 - 117K
    Post edited by Greybro on
    edited March 2017
    Ok. here's what's up and I do agree that it is a particularly poor user experience. Logic says that if the version of Carrara is 8.5, the content will be appropriately named and that latest version is all you would need. However this is not the case. Go back and install Carrara 8, 8.5 & 8.5 Pro Native content and then your presets will show up. also install the Bryce, Carra & Daz Studio IRay HDRI. I've attached a screenshot of everything I installed through DIM. Carrara now loads with the expected content in the bottom panel.
    Best of luck.
    583 x 545 - 61K
  • UnifiedBrainUnifiedBrain Posts: 3,588
    edited March 2017
    Awesome effort you put in there, Greybro.  Above and beyond the call.
    I don't think the HDRI is needed.  But as you said, the Carrara 8 native content is crucial.
    To install Carrara, my experience is to EXACTLY follow the directions on this page.
    Post edited by UnifiedBrain on
    Greybro, thank you for going through the process of elimination. I've not had a chance to revisit since posting.
    I'll see if I can make any progress as the weekend approaches. Thank you to everyone who has weighed in on the conversation:)
    Solved!!!
    I uninstalled then only installed Carrara 8.5 Pro. After (seperately) I installed Carrara 8.5 Pro content and now I am good to go!!!
    Thank you:)
    Realtime said:
    Solved!!!
    Thank you:)
    My pleasure and i'm glad it worked out. I've got to get myself educated on Carrara. It is such a robust program for content creation. Literally, all I've ever done with it is to setup scenes from pre-built content and render. Some of those Howie Farkes sets are just amazingly life like!
